Old 10-22-2014, 11:17 PM
Nitebird Nitebird is offline
Default Could someone post pic of engine mount that fit 1979 Pontiac Trans Am with 400
I think that I may have the wrong engine mounts and it is giving me problems with installing headers on my 1979 Pontiac TA/SE 4speed car with 400 Pontiac.
Could someone post a couple pics of the correct engine mounts for one?
Old 10-22-2014, 11:36 PM
jonathonar89 jonathonar89 is offline
Sometimes the headers are the problem. I have an ever so small interference with the clutch linkage on my 79 4speed that has hooker competition headers. I also had header interference with a shift linkage in a 79 403 auto car I used to own...needed to bend the primary tubes on that one.
Old 10-23-2014, 10:06 AM
The engine mount doesn't fit the mount on the crossmember even without the headers in place so something is wrong with the mounts for sure.
Old 10-23-2014, 10:19 AM
Schurkey Schurkey is online now
Had problems when removing a '70 400 to install a later 455 on Father-In-Law's '77 TA. The '70 block had those aftermarket adapter brackets for early blocks in later chassis. The 455 came from some full-size station wagon. We could shove the cross-bolt through either one of the clamshell cushions, but not both bolts.
Discovered that the F-body uses shorter brackets than the full-size cars from the block to the "clamshell" rubber cushion.
Bought proper F-body block-to-cushion brackets, and all was well.
Old 10-23-2014, 03:30 PM
track73 track73 is offline
I had real problems installing my last engine to the frame mounts. The 6 inch bolts would never go all the way though. I struggled for 2 days, then I loosened the mounts on the engine so there was some "play" and solved the problem.
Old 10-23-2014, 03:52 PM
The engine actually going into the car is a 1975 Pontiac 455.
I finally got them in and this is how I did it. I took the 3 bolts out of the engine block mount and then put the long bolt into the mount...and then lined up the other 3 bolts by moving the engine as needed as I did not have the trans mount crossmember bolted up yet.
Thanks for the input guys! I now have to see if I can bolt up the Dougs headers while the engine mount bolts are in place.
Old 10-23-2014, 03:57 PM
Gerrit's Avatar
Gerrit Gerrit is offline
