Old 10-17-2014, 09:06 AM
2manyT/A'S's Avatar
Default electrical question....110 volt
Thinking about hanging up some flourescent fixtures in a 10 x 20 metal carport....one of those kits with the tin roof.
Was going to hang them on fixture chain....
Anything special that I need to know or do so I won't electrocute myself?
Eye Candy......garage band?
Go full screen & turn it UP!
Old 10-18-2014, 01:29 PM
6t7gto's Avatar
6t7gto 6t7gto is offline
Turn the circuit breaker off.
Black to black
White to white.
Green to ground.
Old 10-18-2014, 01:37 PM
tooski tooski is offline
Enclosed carport, or just one with a roof attached to a house? Shop lites come either with a plug in cord or direct wired. The plug in models usually come with chains for hanging, while the others do not. I would not hang a direct wired fixture as they are meant to be attached to structure. If it is open, I would use the plug in models, plugged into an outdoor GFCI recepacle(s). I am not an electrician but do my own wiring (couple of houses, garages, renos).
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 10-18-2014, 03:31 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
The above, and don't lick the black wire.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 10-19-2014, 12:23 AM
Probird's Avatar
Probird Probird is offline
Black to black
White to white.
Green to ground.
This^^^^. No problem with hanging any fixture with chain and S-hooks. We do it all the time. The bad thing about hanging a fixture in a carport is birds will perch on it and crap on the car.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 10-20-2014, 09:19 AM
Deadhead's Avatar
Deadhead Deadhead is offline
If cord and plug - take apart and hardwire. Get rid of that stupid short plug. Just hardwire in a daisy chain if multiple fixtures back to the switch. I have used many of these when they were 7-8$ and just removed the cord and plug. I also do not like the chains. The bird deal is a good point. Mount direct on surface is better. No banging into them etc, either. 2X4 or similar blocks to mount to building if that makes it easier. Would also make sure that the building is grounded. If not, put a rod in and bond Bldg. to it. Lightening is much more dangerous than 110. And, I would GFI anything you can plug into.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 10-28-2014, 12:46 AM
INJUNBOY's Avatar
INJUNBOY INJUNBOY is offline
If possible you would get a better 8' strip light at an electrical supply. When I used to wire Car Washes we always used High Output (HO) 8 ' strips because when the weather gets cold the HO fixtures still perform well and give you more light than the lumberyard Do It Yourself centers sell. Use 3 wire (2 wire with ground) cord designated for outdoor use if you can or 1/2" sealtite flexible conduit or 1/2" EMT conduit between receptacle boxes or fixtures and get good cord caps from an electrical supply. If you plug every two lights into a single 110 V Receptacle, then if a ballast goes out you can unplug the bad light and use the others until you get time to change the bad ballast. You will spend a little more money,but the ballasts usually last a lot longer and much brighter light. I use 1/4-20 inch eye bolts and fender washers/1/4-20 inch nuts for fixtures if hanging off of cowchain or jack chain.
