Old 10-30-2014, 01:32 AM
rockin78T/A's Avatar
rockin78T/A rockin78T/A is offline
Default 1978 T/A Front springs
I rebuilt the front end of my 1978 T/A, back in 1997. Got the front springs for an A/C car from Ames. The car just sits too high in the front. Been bothering me for years. (About 2-3 inches high). I'm looking for a set of used springs to put her back down lower. The originals looked good, just figured since I was changing everything else, should do the springs too. Currently there is no A/C in the car, but don't think missing A/C would make the car sit so high. Don't really wanna spend the cash to buy new lowering springs, seeing my ex took most my money, but at least left me the T/A!!
God didn't give you a belly just to hang a button on it!
Old 10-30-2014, 04:55 AM
drtracer58 drtracer58 is offline
Did you let it settle before tightening the Nuts on the Upper Control Arm Shaft ?
Old 10-30-2014, 11:36 AM
78w72 78w72 is offline
just take em out & cut about 1" of height. cut the bottom of the spring. 1" will equal ~ 2" of drop on the car. quick, easy, free fix for the ride height issue.
Old 10-30-2014, 05:25 PM
78Macho 78Macho is offline
Default Springs
I had custom springs cut for my car. Coil Spring Specialties in Kansas.
Old 10-30-2014, 09:27 PM
takid455 takid455 is offline
Send a message via AIM to takid455
I have a used set of Old school Rancho GT front and rear springs. Had nice lower stance but not in the weeds. Selling as a matched set but shipping the leafs may be an issue.
Old 10-30-2014, 09:55 PM
redonred81 redonred81 is offline
Default springs
moog 5376 is perfect.did mine last week.my 75 TA was too high also.my hand was passing between tire and fender with 225 70 15 stock tire size,now it doesnt fit,it went down a good inch and a half.good luck
Old 10-31-2014, 05:39 PM
Default springs
its 5276,just checked the box.
Old 11-02-2014, 11:17 PM
Maybe its the tire size. I've got 255/60/15 on 7 inch snowflakes. They only have about 10,000 miles on them, I thought after 15 years they would of dropped a little, I thought about cutting, but figured someone might have an old broken in set laying around
