Old 10-15-2014, 10:18 PM
MD79TA MD79TA is offline
Default 68 convertible power window regulator
Have a 68 GTO convertible with power windows. Looking for regulators and want to know if manual regulator can be converted to power? See lots of manual ones for sale but not power. Front aren't bad but rear are in tough shape. How are the new replacements? Have not seen power ones for sale. Also will all 68 to 72 a body works and are convertible different than hard top. Thanks for any help. I am to the point of maybe converting to manual if it is something I can do. Thanks Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 10-15-2014, 11:13 PM
Scott Thelander's Avatar
Default Hi
I have a nice pair of working 68 convert rear power window regulators....
Scott
pics at [email protected]
Old 10-16-2014, 12:17 AM
paint guy paint guy is offline
Somebody correct me if I'm wrong, but I believe all 68-72 A body rear power window regulators are interchangeable. Fronts, not so much as 68 are one year only, as are 69, with 70-72 the same. Vert and hardtop are the same.
Old 10-16-2014, 05:53 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
I *think* this is correct. Rears are all the same, '68 fronts are unique, '69-72 fronts all interchange even if the '69 are technically different in appearance from '70-72.
Old 10-16-2014, 11:43 AM
scott sent you a pm
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 10-16-2014, 09:51 PM
I know the front are different due to the vent window on all the 68 a bodys. But the real question is the rear and are they the same on the convertible vs hard top. My last option would be to change to manual but do like power and don't know how difficult that swap is. Thanks for the help.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 10-17-2014, 07:50 PM
Default spare pair
here is the spare pair of working 68 LeMans 6 cyl convert bucket seat cars
rear regulators ...Both motors work smoothly ....
pm me a reasonable offer and they are probably yours...
pics below
Scott
[email protected]
ID:	379191   Click image for larger version
Old 11-04-2014, 10:24 PM
Default Hi
Here is the rear window tracks with the convertible only upper bracket...
and the hardware to mount them ....
Sorry it took a couple days to get over there to get em .........
convert on the left .... h top on the right
the upper bracket is unique to the convertible quarter panel
the verts are flatter there and the hardtop curves up to the roof.....so the shape changes
Scott
these are from a 69 skylark convert .........
shoot me an offer thru the pm if you have interest still
I can box em in with the power regulators ...
ID:	380988   Click image for larger version
ID:	380989   Click image for larger version
ID:	380991   Click image for larger version
ID:	380992   Click image for larger version
Old 11-04-2014, 11:31 PM
marxjunk marxjunk is offline
on the front regs...
68 is 68
69 is 69
70 72 interchange..
69 has an equalizer or extra arm that 70-72 dont have......
68-72 the rear regs interchange even between hardtop and convertible....
67 is the last year for "convertible" rear regs..the pinion gear count is different between the two..i think convert is 21 and hardtop is 23..or the other way i cant remeber which
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 11-12-2014, 04:14 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Here's pics of a manual and a power rear regulator.
I also threw in a nice pic showing the difference between 68 and 69 front regulators.
ID:	381770   Click image for larger version
ID:	381771   Click image for larger version
Name:	PW regulator 68 and 69.jpg
68 GTO ragtop
91 T/A
69 XKE
