Can someone tell me where those foam pads go for the cowl grill ?
If you look at the upper cowl under the grill you'll notice raised portions that the insulator should be set into.
3M black weatherstrip adhesive can be used to hold them down in-place.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
Thank you.
Make sure you glue them in the right place. When the cowl is installed you can't see them if they're installed in the right place. Outside of the last slit in the cowl towards the fenders.... under solid metal.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
