Old 11-06-2014, 06:22 PM
bober bober is offline
Default 67 400 #s
I'm checking on a 67 400 eng. and the seller states that it's a special J stamp engine . That's what he was told but there's nothing about any special 400 for 67 that I've seen yet . As far as eng #'s there's only a couple three #'s for 400's . Any #' that I missed ? Thanks for any info !!!
Old 11-06-2014, 09:05 PM
54nomore's Avatar
54nomore 54nomore is offline
Looking through my book of engine codes, etc. :
the 2 letter stamping on the front of the block is the engine code. There are 3 codes in 1967 that contain the letter J.
XJ is a 350 horse 400 from a big car.
WJ is a 376 horse 428 from a big car.
YJ is a 326-2bbl from a Firebird.
Buyer beware
Ron.
Old 11-06-2014, 10:09 PM
Thanks for that info . Is there any thing out of the norm about the J other than ID ? I figure it's nothing more than a 67 400 engine . There was a nice story attached to it also but kinda long !!!!!
Old 11-06-2014, 10:36 PM
54nomore's Avatar
Not that I've heard of, but I'm just a Pontiac enthusiast, not an expert
Best case scenario is that it's really a 428 and they don't know it. (in my opinion)
Old 11-06-2014, 10:45 PM
Thanks for your help !!!
Old 11-07-2014, 02:11 AM
danswrld's Avatar
danswrld danswrld is offline
The two letter code on the passenger side of the front of the block will tell you what it is. I also believe that 428 blocks actually had "428" cast into the underside of the block on the passenger side.
1967 Firebird 400/4spd all #'s matching
1965 GTO 389-4bbl, 4spd. needs restoration
2009 G8 GT...Last Pontiac Muscle
Old 11-07-2014, 07:17 AM
If the head casting number is 143 than it is a 400 As many of the big body cars in 67 got this 400 which came fitted with these 389/ 421 type heads.
Old 11-07-2014, 10:12 AM
gtofreek's Avatar
gtofreek gtofreek is offline
If it has 670 heads, it could be a 400 or 428. Need to get the date code off of it by the distributor, and the code on the front of the block, as they re-used codes throughout the years.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 11-07-2014, 10:39 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
If it is a 67 block the casting #s are. They are at the back by the distributor hard to see in car.
400= 9786133 casting #
428=9786135
326=9786339
Scott
If you always do what you always did
You always get what you always got
