Rear shock and springs. Time to replace these, just curious what you think of these. I do need to lower it a bit. Although UMI has a front and rear kit that's looks interesting. Anybody have any difficulty installing the rear kit.
thanks |
wrong pic, how about these in the rear
The shock mounts on the frame really aren't designed to support the entire weight of the car.
I can't imagine the frame would hold up for very long with those coil over shocks. Am I wrong in my thinking?
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
hhmmm,,, nope, not wrong in your thinking. Very good point
I ended up using some Global West S-60 lowering springs and Bilstein shocks on my '64 Tempest: http://forums.maxperformanceinc.com/...16&postcount=2
I can appreciate the ability to be able to adjust the ride height easily with coil over shocks, but I just wouldn't be able to trust that the mounting points would hold up for the long term. The rear coils are easily trimmed on the '64 -'66 cars since the top of the springs aren't pigtailed, I've trimmed them and heated them a half coil away from the cut with a torch to flatten them so they seat properly in the frame. No issues.
What about the kits that include a support brace that ties in both sides of the frame?
http://abcperformance.net/coilover%20conversion.html
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, [email protected] (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
Interesting link concerning A-body chassis and suspension mods: http://www.chevydiy.com/how-to-upgra...-step-by-step/
Quoted from the website: Another option is to convert the rear to a coil-over system. There is a little more involved at the rear of the car than there is at the front to do a coil-over conversion. The natural location for a coil-over at the rear is where the original shocks mounted, but the upper and lower mounts need to be strengthened in order to now manage load-carrying as well as shock-absorbing duty. Kits range from bolt-on conversions like DSE’s, which includes upper and lower mounting brackets. The ABC Performance kit includes bolt-on brackets and an upper-mount support brace. The Global West system has weld-on brackets to move the coil-overs in front of the axle and mount them to the original upper spring pocket in the frame. I like the Global West approach using the original spring pockets.
Nope, not wrong at all Bart. I was thinking of posting the same thought yesterday but figured someone would over rule me.
Glad I'm not wrong in thinking that.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
I really like the Global West weld on bracket coil-over shocks, I gotta remind my self that I have another iron in the fire right now. Maybe some SPC springs for now.
