Old 09-18-2010, 09:23 PM
Arrow TECH THREAD ARCHIVE - Pontiac Street
We've had a few requests here on the forums to start a Tech forum to archive some good informative tech threads that usually have plenty of pictures to help illustrate what's going on. I can't create a separate forum for them but I can start a thread and stick it at the top of this forum with links to different helpful tech threads.
Please reply here to this thread if you find a thread that was started to offer some good tech info and I'll add the tech thread that you've linked to the list.
I'll start it off:
Pontiac Tri-Power Carburetor Information
https://forums.maxperformanceinc.com...d.php?t=838404
SOME HOLLEY TUNING TIPS
http://forums.maxperformanceinc.com/...d.php?t=811891
Boosting Devices and Methods for Street & Strip
https://forums.maxperformanceinc.com...d.php?t=830273
How to rebuild a Pontiac V8
http://forums.maxperformanceinc.com/...d.php?t=623671
PONTIAC Cylinder Head Tech - Early vs Late
http://forums.maxperformanceinc.com/...d.php?t=636024
PONTIAC Cylinder Head Tech - Round-Port vs D-Port
http://forums.maxperformanceinc.com/...d.php?t=636309
Gain clearance for headers to oil filters
http://forums.maxperformanceinc.com/...d.php?t=468168
My Doug's Installation.............
http://forums.maxperformanceinc.com/...d.php?t=550283
Log Exhaust Manifold Tech
http://forums.maxperformanceinc.com/...d.php?t=630943
Comprehensive Tremec TKO tech tips guide for GTO's
http://forums.maxperformanceinc.com/...d.php?t=466818
Comprehensive Tremec TKO tech tips guide for '67-'69 Firebirds
http://forums.maxperformanceinc.com/...d.php?t=466820
Comprehensive Tremec TKO tech tips guide for '70-'81 Firebirds
http://forums.maxperformanceinc.com/...d.php?t=466821
Disc Brake Install Tutorial -PICS - Front Discs for $ ~150.00
http://forums.maxperformanceinc.com/...d.php?t=593740
Distributor Grease
http://forums.maxperformanceinc.com/...d.php?t=652883
DIY Junkyard Serpentine Belt System
http://forums.maxperformanceinc.com/...d.php?t=690512
New Pontiac 455 engine build video
http://forums.maxperformanceinc.com/...d.php?t=721003
Hurst Wheels - Anatomy
http://forums.maxperformanceinc.com/...d.php?t=748138
Pontiac 9779068 Cam
http://forums.maxperformanceinc.com/...d.php?t=765522
541596 421 Super Duty McKellar #10 Camshaft
http://forums.maxperformanceinc.com/...d.php?t=770467
Oil Pan Mods
http://forums.maxperformanceinc.com/...d.php?t=609229
Valley Pans
http://forums.maxperformanceinc.com/...d.php?t=769185
Measuring for pushrod length
http://forums.maxperformanceinc.com/forums/showthread.php?t=771081
Pulled the trigger on a 2004r tranny. Which dipstick tube for 1970 GTO?
http://forums.maxperformanceinc.com/...d.php?t=771081
389 vs 421 Blocks
http://forums.maxperformanceinc.com/...d.php?t=772995
Installing front sheet metal
http://forums.maxperformanceinc.com/...d.php?t=773122
Using a Tri-power with a non-dimpled timing cover
http://forums.maxperformanceinc.com/...d.php?t=739781
Small Bore = Big Power Cheap?
http://forums.maxperformanceinc.com/...d.php?t=730569
Intake Manifolds - How Much Do They Weigh?
http://forums.maxperformanceinc.com/...d.php?t=772223
Simple Fix For Today's Clutch Fan Running Hot
http://forums.maxperformanceinc.com/...d.php?t=776003
Adapter plates and engine plates
http://forums.maxperformanceinc.com/...d.php?t=732389
1964 421 HO Build
http://forums.maxperformanceinc.com/...d.php?t=771741
389 vs 400 as basis for stroker build
http://forums.maxperformanceinc.com/...d.php?t=702961
Who has shipped cast iron heads and how did you do it????
http://forums.maxperformanceinc.com/...d.php?t=789474
Which brake shoe is the primary?
http://forums.maxperformanceinc.com/...d.php?t=828937
Old 07-28-2011, 11:22 AM
Old Goat 67's Avatar
Bart,
We REALLY DO need a "Library" location for Tech Threads somewhere easier to find that looking around like a chicken with his head still tucked under his wing!
Every time I look for these for someone, I have to look up your "Threads Started" info.
Charles
Old 07-28-2011, 11:33 AM
BTW, is there one somewhere for redoing bucket seats?
Old 11-06-2011, 01:24 PM
SRR's Avatar
SRR SRR is offline
http://www.slyagent.com/tech/
Some good stuff here Ben and I put together.
― Calvin Coolidge
Old 09-21-2012, 01:30 PM
wrenchmen's Avatar
wrenchmen wrenchmen is offline
Here are some Threads I added to my favorites when I was rebuilding my 350.
1st time engine builder here, leave me tips
http://forums.maxperformanceinc.com/...eaning+threads
A couple assembly and break-in questions
http://forums.maxperformanceinc.com/...d.php?t=593983
Dipstick tube in block question
http://forums.maxperformanceinc.com/...=dipstick+tube
Drilling block for improved cooling
http://forums.maxperformanceinc.com/...d.php?t=583733
Help: proper valve stem seal assembly instructions.
http://forums.maxperformanceinc.com/...perfect+circle
HEI tunning tips
http://forums.maxperformanceinc.com/...ebuilding+tips
Pontiac engines are NOT like Chevies...
http://forums.maxperformanceinc.com/...t=valve+length
top 5 things to check my engine builder on.
http://forums.maxperformanceinc.com/...ght=main+bolts
Another Timing Question (Center Plate and Weights)
http://forums.maxperformanceinc.com/...ht=139+weights
There are more on my other computer
1970 Lemans Sport, PPR 383/4spd.
Old 10-07-2014, 04:26 AM
69CATALINADROPTOP 69CATALINADROPTOP is offline
Default Pontiac 400 engine advice needed...
I am looking for some advice on the engine I am building for my car. First of all I am looking for a a smooth idle (it is a convertible) with as much torque as possible on a budget. I am looking for a recommendation as to which parts I should use from what I have to get a good low to mid range power. This car will be a cruiser not a race car.
The block I am using is a 1973 Pontiac 400 X5 block...stock bore. I have 2 sets of heads...
1)1973 4x heads- I believe 2.11 intake/1.66 exhaust and 98CC
2)1970 11 heads-I believe 1.96 intake/1.66 exhaust
And I have 2 intakes
1)Holly Street Dominator single plane
2) Pro Comp Air Gap dual plane
I will be using an eldelbrock 4 barrel carb
Again I want a smooth idle and a good low to mid response. The best fuel economy possible would be nice too.
Which combo should I use? What would be the best cam to use?
Thanks for any advise anyone has.
Old 01-03-2015, 07:48 PM
nmoreilly nmoreilly is offline
Compression, Cylinder Pressure and Cam Selection
http://216.178.81.108/forums/showthr...ht=compression
Old 05-21-2015, 09:50 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Stabbing Distributer For 1`st Startup
http://forums.maxperformanceinc.com/...5&postcount=18
Old 07-15-2016, 05:43 PM
Default Adapter and engine plates
Wow this is long overdue. My apologies.
Gavin posted this in race section and I've added info and pics.http://forums.maxperformanceinc.com/...d.php?t=732389
Old 01-07-2018, 02:17 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Default 1967 670 cylinder head stampings
Hey Guys,
Excellent info and ongoing investigation on the #670 castings, by Rocky Rotella.
http://forums.maxperformanceinc.com/...ight=670+heads
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 01-20-2020, 09:54 AM
Bart, is there a process to download ( I did download & print like 15 years ago but...forgot); Downloadable as text (with images), so we can assemble our own Tech Ref books.
Old 05-28-2025, 09:43 PM
Green Elephant Green Elephant is offline
This is great, lots of great information here. At least two threads that I’ll be reviewing tonight. Thanks b-man.
The Following User Says Thank You to Green Elephant For This Useful Post:
