Old 01-31-2015, 06:53 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default What do I need for clips?
I'm about 75% through my resto and will be needing all the trim clips soon. My car is in the body shop so I'd like to get them now incase holes need to be drilled before paint. I had almost no trim or clips to start with so I have no idea what I need. Could anyone give me the style and quantity I need for all of the moldings?
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-31-2015, 11:12 PM
400 4spd.'s Avatar
Too much to ask for. It would be best to find a comfortable chair and break out a PY catalog. Fisher Body book and assembly guide would also help.
Old 02-01-2015, 06:33 AM
Old Goat 67's Avatar
More info needed. What, where?
Old 02-01-2015, 07:11 AM
helmerrock helmerrock is offline
Windshield trim clips and studs if missing
Rear windshield trim clips and studs if missing
Long lower trim clips depend on early or late style molding
Lower door trim clips
Lower rear qtr trim clips and studs if missing or use screws
Rear qtr dog leg clips 3 butterflys each side
Long trunk molding clips
Vinyl top trim clips (if you have vinyl top)
Front of door beltline clips (not all cars used these)
I think this covers the clips in general. Some are special and not easily available, others are available from PY or Ames. Lots of screws needed along the way as well. Good luck.
Steve
Old 02-01-2015, 08:38 AM
Jeff Hamlin's Avatar
Default 1967 Fisher Body Manual
FWIW;
This section will cover all exterior trim/molding.
Does not give counts but will help you determine what you should be looking for.
http://www.thefirstgensite.com/libra...7S17P39_48.pdf
Old 02-01-2015, 08:58 PM
67gtospud's Avatar
Thanks guys, I need every clip for every molding on the car. I will need new studs for the front and rear window moldings as well. No vinyl top, and I have the 2nd design rocker panels. I may have the rocker panel molding clips though; I will have to dig through my parts stash next weekend
Old 02-01-2015, 11:52 PM
400 4spd.'s Avatar
It would be nice if someone would offer a complete and correct clip and fastener kit for these cars.
