Old 03-08-2015, 05:49 PM
Redpiston Redpiston is online now
Default Dash Pad
Is the dash pad with AC and speaker the same on a 65 & 66? I found a 65 that would be a good core to have redone and thought I might pick it up. Any comment on value also would be appreciated.
Old 03-08-2015, 07:13 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
No. the shape is a little different. AFAIK the speaker grill is the same, and the mount for the speaker (isn't attached to the pad on A/C cars) is the same.
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 03-08-2015, 10:11 PM
The ac controls and radio are the same correct?
Old 03-08-2015, 10:40 PM
LASJayhawk's Avatar
AFAIK the a/c controls are the same ( too far into a bourbon bottle to look it up ATM)
Radios look the same, but the rear chassis mount on the right side is in a different location on the 65 and 66. Don't remember if there is an internal electrical difference between the 2 on the AM radios, but the 13 transistor 66 am/fm is a much better design than the 11 transistor 65 unit. But the 66 am/fm units are more prone to blowing the AM RF amp transistor than the poorer performing 65 units.
Old 03-09-2015, 06:52 AM
Deadhead's Avatar
Deadhead Deadhead is offline
Same in appearance on radio etc. Dashpads are different. I bleive they can be interchanged, but do not look the same. Would expect that the plastic plenum going to the center AC vent would be different too.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 03-09-2015, 12:51 PM
LASJayhawk's Avatar
65 will have a port on the vacuum switch for the STV valve, 66 may not have the port as they were all POA's. When they did the changeover in 65 they just pluged the port, you would need to do the same.
ETA: M&H list an a/c harness for 65 but not for 66. So I'm not sure if there is a difference in the electrical connections at the panel or not.
Old 03-09-2015, 01:58 PM
I noticed when I was looking under the dash yesterday there were two vacuum lines plugged up with screws. Lines we all bundled pretty neatly. Did not look like someone had been messing with them.
Old 03-11-2015, 07:30 AM
70ra455's Avatar
70ra455 70ra455 is offline
Not only is the shape of the pad different on the front edges (rounded vs. flat bevel) also the a/c vents are way different ... the '65 has a much flatter hump and a much narrower vent whereas the '66 has a larger hump and a much wider vent.
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 03-12-2015, 05:54 PM
stevep's Avatar
stevep stevep is offline
Also the courtesy light is in a different place between the 2 years, which will require a slight modification.
Old 07-19-2016, 10:46 PM
Default Resurrecting thread
Will a 66 Bonneville AC dash pad fit the Cat? I thought they were the same. If I am going to send it in to refurb, the core would be the same wouldn't it?
Also is the steering wheel the same other than the wood grain in the horn bar?
Old 07-19-2016, 11:49 PM
70ra455's Avatar
66 Bonnie ac dash same as 66 Cat.
Clear steering wheels the same other than wood insert.
What color dash are you looking for?
Old 07-20-2016, 12:16 PM
i have 2+2 with blue interior. Mine is not cracked but the area around the ac is swollen pretty good. I thought I might get a good core and have it done. That way I dont have my car tore apart waiting on it.
Old 07-20-2016, 05:30 PM
70ra455's Avatar
Let me know if you're interested in getting it done ... I can hook you up. Just got mine done in Turquoise with NOS material. I'm sure I can get it done in NOS blue.
Old 07-20-2016, 06:31 PM
Thanks. Need to get a good core first. I plan on stripping it to metal and epoxy coat it. Then have it done. You have someone other than Just Dashes in CA to do it?
Old 07-20-2016, 06:54 PM
70ra455's Avatar
Actually we're doing them together. I have cores as well if you need. NOS material is more expensive but even with that I can save you 100's from Just Dashes.
Old 07-20-2016, 09:43 PM
mgarblik mgarblik is offline
70RA455, could you PM me about possibly restoring a 62 Catalina full dash pad no AC. I have a decent core and vinyl material yardage. Thank you.
Old 07-21-2016, 12:31 AM
70ra455's Avatar
Please email me a pic of the core to [email protected]. ... the more details I have the better idea I'll have. Thanks
Old 07-21-2016, 10:21 AM
Willshire's Avatar
Willshire Willshire is offline
I too would like to discuss a 64 gp dash with you. I will take a pic tonight and send. Shipping alone would be considerable cheaper as it may be easier to drop it off than ship lol
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 07-21-2016, 03:23 PM
70ra455's Avatar
I'll wait for the pic. Thanks
Old 07-21-2016, 07:13 PM
I sent an e-mail and 10 pics. Did you get them?
