Old 04-06-2015, 02:44 PM
Not much actual room (flexibility) for the crank to be in the wrong spot and not have the roll pin, distributor gear, etc see a lot of stress.
Tom Vaught
Old 04-06-2015, 02:52 PM
461-69bird's Avatar
461-69bird 461-69bird is offline
sorry Tom, I`m not understanding the answer, could you put it in simple terms for me, yes or no haha.
69 Firebird
472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120
Old 04-06-2015, 04:38 PM
Looks like the break point started at the drill hole, likely started by a sharp edge!
Old 04-06-2015, 05:59 PM
shaker455's Avatar
If the block checks out you can put steel caps on the block is the block shows no other damage. Inspect the block for the oil pump shaft guide (cast in the block) still being there and in good shape.
Tom Vaught
Rick,
X2 on Tom's post....don't reuse the caps and get some steel caps.
If that's a 2-bolt block I'd consider splayed caps.
Either way sorry to see the destruction.
Old 04-06-2015, 06:12 PM
johnta1 johnta1 is online now
I'd wait and see what the block looks like when tore apart.
I'd say the block is cracked somewhere in the main bulkhead.
Old 04-06-2015, 08:07 PM
Well I tried in simple terms and it was still taking too much typing so I bailed out on a reply
Old 04-06-2015, 08:26 PM
Dragncar Dragncar is offline
If it is a easily replaced 2 bolt block, nothing special sort of deal I would not even think about running that block again in a performance build. Could not sleep at night myself.
Sorry about your engine. But those offshore cast cranks have had issues eating thrust bearings and or failing where they should not.
I have flogged PMD cranks and never hurt one of them.
Old 04-07-2015, 07:24 PM
70 bird's Avatar
70 bird 70 bird is offline
X2 I know your not in the U.S. But I would try real hard to find another block.
Old 04-08-2015, 07:50 AM
Chris Uratchko Chris Uratchko is offline
Unless it's the picture, to me it looks like the crank was cracked for a while....
Uratchko Racing Engines
www.ure-racing.com
Old 04-08-2015, 07:56 AM
Originally Posted by RA462 View Post
I broke a factory "N" 455 crank about the same point on the track once. It was like I killed the ignition. No bang just stopped. I broke the #5 rod journal right off the crank. In our opinion the journal fillets should have been larger creating a stress concentration piont. The power from all the cylinders has to go through that #5 rod journal since the resistance on the engine is the flex plate. Just my 2 cents. Sorry about your engine.
great data point.
Old 04-08-2015, 07:23 PM
taff2's Avatar
taff2 taff2 is offline
Looking at the dark areas in the crack it does appear to have started cracking a while back. Definitely got some cap fretting,what are you revving it to? And why are there main studs on only number 2 and 4 mains?
You could also do with modifying the thrust bearing, file a small chamfer along the parting lines of the shells- about 0.020" will do it. Have you restricted the oil flow to the converter/cooling circuit in the TH400? You sound like you have a recurring problem with the thrust bearing and modified TH400's are notorious for causing engine thrust bearing wear. Increased trans line pressure translates into higher cooler circuit pressure which can force the converter forward,causing thrust bearing problems.
Old 04-08-2015, 08:38 PM
455firebird1969's Avatar
I see what you are talking about, but I don't think they are "beach marks". I don't see a growth pattern
Old 04-08-2015, 09:19 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Yes, definitely. I experienced thrust issues with my '64 GTO engine until we made these two mods.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 04-09-2015, 01:17 PM
461-69bird's Avatar
shifting at 5500, max ever revved to 6200 but usually 5800 at finish line
don`t know about the studs, that`s how it was built. the Milodon windage tray was bolted to the studs
both of those mods were done
69 Firebird
Old 04-09-2015, 02:36 PM
i82much's Avatar
i82much i82much is offline
I wonder if post #2 in this thread answers your question?
http://www.gtoforum.com/f50/455-main...uestion-55713/
Old 04-09-2015, 09:20 PM
The beach marks are a true yield strength limit indicator, yet was it organic defects in the material or a machining "stress riser" that got allowed to propagate. Hmmmmm.
Old 04-09-2015, 10:38 PM
i82much's Avatar
Talking
You know, I never know what the heck you are talking about, but I always get the feeling you know exactly what you are talking about.
  #38
Old 04-10-2015, 03:41 PM
GTO's Avatar
GTO GTO is offline
Talking
LOL.
Runner Up Q16 Norwalk 2013!
  #39
Old 04-10-2015, 04:44 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Very well said
Go fast, see Elvis!
