Old 04-24-2015, 07:35 PM
cnc's Avatar
cnc cnc is offline
Default Wood grain Dash insert
So on my 73 which has the wood grain dash there is the section on the right Side where the reardefrost switch and possibly other switche were/are
My car has no rear defrost And I have replaced my original non ac insert with a ralley gauge cluster since I converted to ralley gauges
So now I have this open hole in the dash....is there a insert to cover the hole .likethe cars that had the switches ( I have no switches ) or do I need to make something up by cutting up a damaged wood grain insert.....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 04-24-2015, 08:39 PM
necdb3's Avatar
necdb3 necdb3 is offline
There is a wood grain block off plate if you don't have switches.
Old 04-24-2015, 08:47 PM
cnc's Avatar
cnc cnc is offline
Where Are they available ...I've seen the Trans am swirl insert but not wood grain...
Old 04-25-2015, 07:39 AM
necdb3's Avatar
I don't see anyone that sells it new. Maybe post it in the "parts wanted" section here on the board.
Dave
Old 04-25-2015, 08:31 AM
cnc's Avatar
cnc cnc is offline
Thanks Dave
Old 04-25-2015, 06:28 PM
A Schab A Schab is offline
I'll be in the area where I got the motor mounts for you next weekend,there is still a lot of early birds there. I will check for you if you want me to.
Old 04-25-2015, 06:47 PM
cnc's Avatar
cnc cnc is offline
That would be great even a insert that's beat up cheap .....like $25ish and cut a piece out for me .now can that happen not sure....... how confident do u feel about matchin it up..is the real issue....lol......
I wish I could send u a piece to take to match .....Chris
Old 04-25-2015, 06:49 PM
cnc's Avatar
cnc cnc is offline
The original panel that was in the car that area is blocked off as part of the dash insert
So are they available as a stand alone block off plate like this but in the wood grain....????
Old 04-25-2015, 06:54 PM
cnc's Avatar
cnc cnc is offline
I think I might be into actually cutting a section from a bezel...but not sure....
Old 04-25-2015, 07:04 PM
cnc's Avatar
cnc cnc is offline
Original dash
Old 04-26-2015, 08:01 PM
Formulabruce's Avatar
I have a plate for the Correct '73 woodgrain with one factory switch hole ( the right side rear defrost/fog) '73 and '74 are all alone in the color and grain. You will not find a blank back fill panel as you see they come with a solid panel there.
PS, going to sell your old bezel? I would be interested.
" Long may we DRIVE !"
Old 04-27-2015, 07:37 AM
cnc's Avatar
cnc cnc is offline
Hey Formulabruce
I didn't think I had ever seen a removable block off plate in the wood grain......
Unfortunately I don't have a need for a panel with a switch cut out....
Looks like I will have to get an old insert and cut one up ...OR I have been told the Cherry oak is very close I am currently checking into 3m for some samples..and then make my own plate if need be
Norwalk is coming too...so might find a bezel there to cut....
As for my old Bezel..... for right now I'm kinda wanting to hang onto it......for now.....
thanks for trying to help.....Chris
Old 04-27-2015, 09:56 AM
transam1972 transam1972 is offline
Default DASH BEZELS
are both of the pictured dash bezels 1973?..as I do not understand...1973 is that the first year for real black bezels on the Formula and others??..what years use the test -tube tinder that rolls onto the bezels??..CNC keep looking and you will find the correct part..I would rather you use the one FORMULABRUCE has and I will send you a new defog switch to put in place till you do find the part (please do not harm any bezels)
Old 04-27-2015, 11:37 AM
Glenn, Finding a wrecked 73-74 bezel with correct woodgrain and cutting out, or "making" this part with a solid piece of that Bezel should be pretty easy.
Old 04-27-2015, 02:55 PM
cnc's Avatar
cnc cnc is offline
yes both bezels I pictured I am to believe are 73 the car I have is/was pretty original...
I really dont want to buy a plate, borrow a switch till i get what I want
Last resort is finding a bezel and cutting..... if I was that desperate i would have cut up my mint one ...but Im not gonna do something that stupid either......Im currently looking to match something up...im frugal too....lol
Ive been driving for a year like this so its not a big deal...
Im just keeping an eye out and if something comes up it does if not...keep looking
Old 04-27-2015, 02:57 PM
cnc's Avatar
cnc cnc is offline
Formulabruce if I decide to sell u have first dibs...
Old 04-27-2015, 03:51 PM
Default borrow??
who said borrow?...sell it on E BAY and get the part you need (but please DO NOT cut up any 1973 WOODGRAIN BEZELS AS THEY NO LONGER MAKE THEM...sorry, I am just trying to fit in...actually have you checked the woodgrain floor tile at Lowes or the DEPOT??..OR BETTER YET, YOU COULD MAKE A PLATE OUT OF REAL WOOD AND STAIN IT TO THE CORRECT COLOR...please feel free to steal my ideas...meanwhile,..I am checking E BAY for that part..wish me luck
Old 04-27-2015, 06:06 PM
cnc's Avatar
cnc cnc is offline
[QUOTE=transam1972;5394263]who said borrow?...sell it on E BAY and get the part you need (but please DO NOT cut up any 1973 WOODGRAIN BEZELS AS THEY NO LONGER MAKE THEM...sorry, I am just trying to fit in...actually have you checked the woodgrain floor tile at Lowes or the DEPOT??..OR BETTER YET, YOU COULD MAKE A PLATE OUT OF REAL WOOD AND STAIN IT TO THE CORRECT COLOR...please feel free to steal my ideas...meanwhile,..I am checking E BAY for that part..wish me luck
Hahaha....good luck on your search as I too just talked with someone about some vinyl to try to match the bezel.....don't worry...I won't hack up a known good bezel.....😀
Old 04-27-2015, 09:47 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Chris, let me know if you find the correct wood grain name.
ID:	396322   Click image for larger version
ID:	396324   Click image for larger version
ID:	396325   Click image for larger version
Old 04-28-2015, 03:08 AM
FASTASSBIRD FASTASSBIRD is offline
I think I have one I can measure next week if you want. I will post pics of it when I get home. It's a solid wood grain block off plate. May be from a 71 or 72 however. Don't know how to tell the difference
