Old 05-16-2018, 09:03 PM
gtoguys gtoguys is offline
I found the wire I was looking for. The tach light harness plugs into the clock harness.
Old 05-16-2018, 09:36 PM
mgarblik mgarblik is offline
Originally Posted by lilabner View Post
Need nimble fingers on a 61, but it wasn't hard to do.
That interior is beeeutiful.
Old 07-06-2022, 06:35 PM
I see this thread came up again. What cup and adapter did you use to mount the tach on your 61? Was it the stock 63-64 parts. Still want to mount a tach on my 62 and haven't pulled the trigger yet.
Old 07-18-2022, 05:13 PM
lilabner's Avatar
lilabner lilabner is offline
I dont remember.Either a 63 0r the 61 that mounted on the tunnel. Tach is a 61. It wasnt a problem.
Old 05-23-2018, 09:08 AM
lilabner's Avatar
I sent you an email with pictures but it came back server unavailable at this time..
Old 05-23-2018, 04:06 PM
It has been talked about on here before, but I can confirm that my TI tach doesn't work with points. Any one got a points tach? Maybe a slight trade for the TI tach?
Old 06-16-2018, 05:50 PM
U47 U47 is offline
I saw a article on a 64 GP in Hemmings Classic car magazine a few months back. This car had the vacuum gauge installed in the dash like all above photos. My recollection is Pontiac never did this? Anyone know for sure? Also, anyone know if a 63/64 Catalina without a console could be ordered with a vacuum gauge?
Thanks in advance.
Old 06-16-2018, 06:49 PM
AZ64GP AZ64GP is offline
Thanks in advance.
I’ve seen that Hemmings article too. The owner removed the upper part of the center console to install the aftermarket A/C. Since the original location of the vacuum gauge on the console was removed, the owner mounted it on the dash. All automatic GPs in ‘63 and ‘64 had the vacuum gauge mounted on the console and not the dash. The tach was optional on the dash. Someone else can reply regarding manual transmission cars, as those may have had the tach on the console. I don’t believe the vacuum gauge was ever installed on the dash as is seen on the car in the magazine.
Old 06-16-2018, 09:53 PM
U47 U47 is offline
That was quite a article Hemmings Classic Car put out. The A/C compressor and brackets was Pontiac, so what I think happened was the car had a dealer install A/C and they removed the upper portion of the console to add the add on ducting and switches. The car has the correct rocker molding, however the rocker molding front fender extension, which G/P and Catalina do not have has the Bonneville ribbed type. The article also talks about the 389 and then says only the 421 engines used solid lifters!
By 1964 the SD program was all over, no solids after 1963 to my knowledge!
I think there are probably better examples of 64 G/P's out there that they could have used. They also really need a Pontiac person to proof read their articles.
Old 07-06-2022, 12:03 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
original off the road 45 years 64 Grand Prix 4 speed car I just picked up , seems to be a STD 389-4v car with STD open 3.42 rear but had BOTH the OEM vacuum gage on the console plate and a dash mounted OEM tach....
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
