73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 05-22-2015, 06:12 PM
zeebo's Avatar
zeebo zeebo is offline
Default 73 lemans shifter porch repop?
im thinking someone repops the 73 lemans 4 speed shifter porch..it is just slipping my mind right now...anyone? thanks
Old 05-22-2015, 07:05 PM
It may take a little bit of searching but you can find it on ebay as I've seen them on there more then a few times.
Old 05-23-2015, 10:16 AM
75cancup 75cancup is offline
The Parts place has them .
Ban low performance drivers... Not high performance cars.
Old 05-27-2015, 11:40 AM
sdx455's Avatar
sdx455 sdx455 is offline
What is a shifter porch?
73 GTO 455 TKO 600 3.90
Old 05-27-2015, 05:40 PM
A shifter porch is the metal part of the floor that looks like an upside down bowl that is either bolted or welded to the floor where the shifter comes through the floor. It creates a flat portion so you can put the boot & ring over the carpet to seal the floor.
Old 05-27-2015, 06:46 PM
Held for Ransom's Avatar
It's also known as a hump.
Ames doesn't have one listed, as far as I can see. TPP sells it under PN MT10943Z.
https://www.thepartsplaceinc.com/Pop...D=MT10943Z.jpg
Old 05-28-2015, 10:17 AM
sdx455's Avatar
I bought one but didn't need it ,when I installed the tko 600 . thought it was called it a shifter hump
Old 05-29-2015, 01:02 AM
Alvin's Avatar
Alvin Alvin is offline
Question
Is that correct for the '73-77 ABody? If so could you provide the page link on the Parts Place website? When I searched their site I could only find 67-72 info... Thxs.
Old 05-29-2015, 06:07 AM
If you go to https://www.thepartsplaceinc.com and type in MT10943Z in the Part # Search box it lists it the same for 1973-1977 Monte Carlo, Chevelle, El Camino, GTO/LeMans, Cutlass/442 and Skylark/GS/Regal/GN.
Old 05-29-2015, 07:14 AM
Alvin's Avatar
Thumbs up
Great info, thanks for the reply w exact info. Below is my screen grab of same for OP zeebo's FYI:
Old 05-31-2015, 09:48 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
How a factory one looks installed (from underneath)
http://www.pontiacpower.org/
