Old 05-30-2015, 03:45 PM
ta man ta man is offline
New intake in ..as well as three sets of 1233's..time to start prepping.
  #102
Old 05-30-2015, 06:03 PM
Cliff R's Avatar
Cliff R Cliff R is offline
"Cliff what carb on the motor? Q jet or square bore? Which cylinder?"
The owner runs one of our big cfm q-jets based on an early 1980's Chevy truck carb, pretty much the same as an Edelbrock 1910 with the booster rings removed.
Can't remember which cylinder, but the q-jet isn't to blame, he had a 2" spacer on the RPM intake so I doubt if there were any distributions issues, and the problems went away as soon as he changed intake manifolds.
The owner also has a Quick Fuel 1000 cfm carb, but it runs no quicker anyplace than the Q-jet, and the q-jet idles and driver better down the return road, and easier to stage and come up on the brake (foot braked car). So he uses the Q-jet instead of the big Holley, and has now for over 10 years.......Cliff
  #103
Old 05-30-2015, 06:07 PM
Cliff R's Avatar
"I will be testing intakes this year,I'm swapping a rpm on to see what spacers it likes.Removing the water crossover from both intakes.Both intakes will be port matched to my heads.Then after I have the rpm dialed in for spacers I will test both on the same day at the track."
I'll be looking for those results. I found that my CNC ported HO intake from Dave at SD is just as quick if not a tad quicker than the RPM intake I removed, at least thru the 1/8th mile.
I didn't back to back them, but have compared a lot of runs in similar weather and track conditions, and the car hasn't slowed down anyplace with the HO intake in place, and it's a LOT better fit than the taller RPM intake.
I still liked the RPM and ran well with it, but like using the stock air cleaner, filter, lid and Shaker assembly better, which is all drop on with the HO intake. Using the RPM required a different Shaker and a custom air filter in the opening of it, which I never really liked......Cliff
  #104
Old 05-31-2015, 12:21 AM
If it was not a distribution problem what caused the issue with the intake/carb combo?
  #105
Old 05-31-2015, 08:40 AM
Cliff R's Avatar
I don't understand the question.
The owner lost the same rod bearing twice, so switched to a single plane intake, same carb, 2" spacer, and the issues went away. This most likely means that the RPM intake was leaning out that cylinder for one reason or another.
I do know that several runners on the RPM are more restrictive than the others where they "lay over" each other in the center of the intake. Still a good intake, and fine for pretty big power. Out past 700hp there are certainly better choices....IMHO.....Cliff
  #106
Old 05-31-2015, 08:19 PM
77 TRASHCAN's Avatar
Originally Posted by Torquewar View Post
I will chime in and since me and TA man get together when we can.
My combo is the same except with E-Heads done by SD 330s. I have always been running a Quad and a RPM. The RPM was port matched and played with a little by me. Quad has always been dead nuts reliable and for a street car i love it.
Have disscussed with Ernie about a T2 and prepped Holley see what it may do .
The T2 will be sent to SD for some work and need to source a carb.
Its interesting to see real strip results with combos . Hope it all pays off for the effort and maybe with some guys here on this site.
CNC will be going sometime this year with my tires.....its all fun.
Looking forward to more installments!
A real street car w/ 3.08 gears. In a way you all are doing similar things that Jim Hand has been doing, except w/ aftermarket parts.
Do the 3 of you live fairly close, or close to the track???
Shut it off
Shut it off
  #107
Old 05-31-2015, 10:36 PM
|I'm 100 miles away from St Thomas Raceway Park..I change a part drive 100 miles there make a Cpl runs evaluate and drive home!Andy and Chris are a little closer..
  #108
Old 06-01-2015, 09:30 AM
Here you said you doubt there was distribution problems so I was confused then how the intake was the cause.
  #109
Old 06-06-2015, 10:33 PM
I've had the new rpm intake on for quite a few street miles,car runs a little smoother than before,sounds a little different,power wise hard to tell on the street.Just running the carb on the intake for now no spacers.May be going to the track next weekend testing spacers.
  #110
Old 06-07-2015, 08:43 AM
CLIFF,
Is the RPM the better 455 choice vs the Performer RPM? or am I referring to the same casting?
  #111
Old 06-07-2015, 02:36 PM
Originally Posted by Half-Inch Stud View Post
CLIFF,
Same casting....
  #112
Old 06-07-2015, 02:53 PM
Pontiac Derek Pontiac Derek is offline
The RPM is much better than the performer or P4B Q jet flange, Especially ported, you will gain 10hp up top but lose 10ft lbs down low with a 1" open spacer, a 1" open spacer will net you your best et's and you will be right there with a T2 that is untill the T2 is fully ported with a 1" open spacer fwiw
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #113
Old 06-07-2015, 03:07 PM
Thanks I gasket matched my rpm intake to my heads,blended it back about 2 inches.I don't think this intake will make more peak power than my Torker 2,but will it make up for the peak horsepower loss with the higher torque numbers down in the rpm range?My torker 2 ran its best with a one inch tapered 4 hole Wilson spacer,you could actually feel the torque difference and throttle response over a one inch spacer.
  #114
Old 06-07-2015, 04:03 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Good luck with your testing it will be interesting to see your results. About 10 years ago I tested the Torker II against the RPM in my 80 Trans Am with a pump gas 462, ported iron heads, 2800 stall and 3.42 gears. My results were;
Performer RPM 11.42 @ 118.65 with 1.673
Torker II. 11.51 @ 118.31 with 1.685
I remember analyzing the time slips and thinking the T2 was a bit slower between the 60 ft and the 330 ft mark.
I had to go up two jet size when I installed the T2 and use slightly larger pump nozzles.
Keep up the good work!
Go fast, see Elvis!
  #115
Old 06-08-2015, 03:59 AM
That's what I'm thinking will happen....thanks for the heads up on carb setup...I've been thinking of less pump shot with the rpm..I've had a couple seasons dialing in the 950hp on the torker 2 ,it leaves pretty good.May take a bit to really dial in the rpm for a fair fight.
  #116
Old 06-08-2015, 09:49 AM
I have, and Dave at SD has a interesting porting program for the T2 intake, normally porting=making things bigger which slows air down, except ive found by porting the T2, plenum and runners it actually picks up air speed and torque throughout the rpm range, the RPM is Hard to beat in a streetable setup but it can and has been done, the Tapered 4 hole spacers do better on the street/track than the open spacer does until the cubes get up over 470 it seems to start needing a bit more plenum volume, depending on having the correct combo, good job and good luck testing! I know one thing you wont gain much going to a lower gear set! Got to love these Pontiacs! Tell a chevy guy you run 3.08 gears and then your et lol thats a funny look!
  #117
Old 07-09-2015, 12:25 PM
All this testing may come to an end soon,I've decided to make the best of my engine combo.The 3.08's are great on the highway...but I really want now is to push into the 10's...and really give SD's head cam combo what it deserves..plus I want to lay a spanking on my buddy with his 555 BBC on 110 octane !
  #118
Old 07-09-2015, 12:28 PM
leeklm's Avatar
leeklm leeklm is offline
It was bound to happen
  #119
Old 07-09-2015, 03:09 PM
Since my 81 has 3.08s and the 468(0.060 over 455) I have ion the stand is destined to go in it I've been watching closely.
SD ported E heads and Torker II. My hand ported flowed a little better than Dave's CNC, but his was on an EFI one in case I go crazy in the future instead of carbs. I have a Shaker 455 HP 1000 that wil go on it and it just has a Stump Puller
  #120
Old 07-09-2015, 04:24 PM
PAUL K's Avatar
How fast is your buddies 555 BBC?
Go fast, see Elvis!
