#61
Where are you pulling the vacuum pump from?
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#62
Yeah. Vac pump oil mess. I know getting a lot more oil up top which is needed to cool springs,yada,yada.
I moved suction tube from top between 2&4 to the front of VC. With old location it filled tank every three passes. Now it over flows on single pass. Going to move location back to between 2&4 with same baffle but use a separator tank in suction line between VC & pump. Car launches straight and stable on top end. !! Nice handling car.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#63
I had the same problem but in a street condition, about 10 miles of easy driving and the tank overflowed. The fittings were between 2-4 and 3-5 on VC's. I ended up moving them to the fronts and welding in baffle plates inside the VC, I also kept adjusting the Aerospace VP regulator till I got the results I wanted. Also, the more I drive it the better the ring seal is and thus less blow-by. I was starting to think my motor would never seal up but it taking some time for the rings to seat and now getting even less oil in the tank.
#64
![]() Quote:
Dave Polichena |
#65
![]() Quote:
In my experience you have a vac leak somewhere in the system. On a well sealed up engine, I don't generally get anything in the breather tank. But with a leak, such as an external leak, or an internal leak(ring seal), you develop a flow path and it picks up oil along the way, and out into the vac pump. If the engine is sealed it's not as particular about baffling and source(valve cover works best)... |
#66
I bought some cleaning solvent and rubber compound from a local go-cart racing business and treated my two and a half year old slicks about six times this week. Today was the first time I have had traction with this new motor. It has nine passes on it now, and I'm happy with the results. I told Jim (CVMS) I wanted two tenths when I dropped off a block, crank and Pistons a couple years ago. I've had the machined engine parts in my possession since early 2014, but it took me until recently to get it together and making passes. This is my best pass to date, 6.32 @ 108.MPH.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#67
60Man - Installed these on both my motors. No more issues w/ vacuum pump filling the puke tank. http://www.jegs.com/i/Moroso/710/85471/10002/-1
#68
![]() Quote:
Aren't you just moving the oil collection to the intake side of the pump as opposed to the puke tank? Or does this somehow reduce the volume collected? Stuart |
#69
![]() Quote:
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U ![]() |
#70
http://forums.maxperformanceinc.com/...p?albumid=1471
Stock 455 block with 2 bolt studded mains + .03 bore with Ross 4.18 pistons, offset ground 103 N crankshaft, Eagle rods using 2.2 big ends, moly top sealed power rings that don't need a vacuum pump. Comp Cams 300B-6 solid lifter camshaft. E-heads by Dave Wilcox, and a E-85 Holley 850 DP by Eric Niefert on a T2. My RamAir air cleaner was hitting the underside of the hood with a 1" spacer, so I took it to the belt sander and tapered it giving it a forward tilt. Now the open spacer is 1/2" in the front and 1" in the back. My PTC converter flashed to 4000 RPM behind my old 463 that ran a best of 6.41 @106 MPH. This new engine only has nine passes, and these recent passes are after being sidelined since the fall of 2012, so I'm a little rusty at the tree, but more seat time should cure that. I forgot to see where the converter is flashing to, Inspect its still near 4000 because it feels really tight.
#71
I have a freshly overhauled T-400, 390 gears on a spool, 9x30 Hoosier radial drag slicks and Cal-Tracs. I think the car weighed about 3400. Last winter I took some weight off of the front buy removing the heater core assembly, inner fenders, and a few other items. My alternator stopped charging, so I put another battery in the trunk to get through the race, so all the weight I took off the front went back into the trunk. I still haven't decided on which alternator to run? I want something that charges better than my old stock unit, and go back to running one battery.
#72
![]() Quote:
#73
Yeah, it's about 12.7/1 and I was shifting at 6000.
It has a nice little ethanol crackle at idle, I'm happy with it.
#74
I finally got some time slips of my own to post. I made two passes at SIR last night. The density altitude was over 6,000' and the starting line wasn't well prepped. It was a TNT night, with a very low turnout. First pass was 8.033 @ 170.41 and the second was 8.026 @ 170.97. My 60-foots were way off at 1.24 and I struggled to keep it straight the first 200' or so. After that, it straightened out and felt good the rest of the way. The good news is it felt fine at the top end without my air splitter, so I'll keep it the way it is. I like the "stock" look better.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#75
![]() Quote:
#76
BITCHIN!!!
#77
It may be hot out here this time of year, but we've got some nice sunsets.
Jim
