Old 06-10-2015, 04:05 PM
1966geeto 1966geeto is offline
Default Rear springs
I installed a set of vert springs in my 66 as recommended by our former host I wanted to get about an inch of height without adding any extras. I did not get the results I was looking for and was wondering if big car rear springs would work or do I just bite the bullet and have them made. Any suggestions.
Old 06-10-2015, 06:30 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Spacers?
color me gone
Old 06-10-2015, 06:38 PM
I looked at the billet spacers that Jeggs has just unsure of how they mount do the have insulators on both sides ?
Old 06-10-2015, 08:36 PM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
Default Wagon springs.
I wanted to ask have you considered wagon springs? On '68-'72 models, they have a tendency to sag.
Old 06-10-2015, 09:06 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Went through this with my 69 GTO & got spacers from Summit for under $50 as I recall. I'm pretty sure they were 1 1/2" & went between rear diff & bottom of spring. Insulator went between spring & body on top, nothing between spring & diff. I have many miles & burnouts since with no issues.
Old 06-10-2015, 10:12 PM
A '66 rear spring simply bolts down to the spring pad on the rear axle. No lower insulator is used, unlike the '67 -'72 cars.
You can either buy or make some spacers in the desired thickness and buy longer bolts. It's very easy to keep your current springs and adjust your rear ride height to exactly where you want it using a flat steel or aluminum spacer with a 1/2" hole drilled through it.
Old 06-11-2015, 06:57 AM
AG's Avatar
AG AG is offline
I put wagon springs on my '65 and the ride height is perfect.
Old 06-11-2015, 04:37 PM
Nice!!
Old 06-11-2015, 09:00 PM
roy381 roy381 is offline
AG, what did the wagon springs come off of ?
Old 06-12-2015, 06:27 AM
The Champ's Avatar
^ Most likely a LeMans/Tempest wagon of the same year.
Old 06-22-2015, 10:12 PM
NO67GTO's Avatar
NO67GTO NO67GTO is offline
I put wagon springs in my LeMans and it raise the bumper 1&1/2"
Giving To Others!!!
V.P. Pioneer Valley GTO Association
www.pvgto.com
67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008
68 GTO H.O. in progress?
Old 06-22-2015, 11:12 PM
1969GTO's Avatar
Default spacers I removed from my 69 GTO
I removed them and installed a new set and ride height was fine
color me gone
Old 06-23-2015, 06:25 AM
What year and model springs ?
Old 06-23-2015, 07:29 AM
NO67GTO's Avatar
I don't remember its been 20 yrs
Giving To Others!!!
www.pvgto.com
