Old 11-07-2013, 02:51 AM
blueghoast's Avatar
Default 461 Build
Heres some pics of the start of your motor build tpssonic.
And a couple others to do too.
I'll be a little busy this winter. I love it !!!!!!!!!!!!!!!!!!!!!!!!
GT.
ID:	342195   Click image for larger version
ID:	342196   Click image for larger version
ID:	342197   Click image for larger version
ID:	342198   Click image for larger version
  #42
Old 11-09-2013, 07:46 PM
tpssonic's Avatar
tpssonic tpssonic is offline
Excellent GT. Keep me posted!
  #43
Old 11-09-2013, 08:29 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Default stealth
400 badged....497ci stroker, here is one I did awhile back. I even fooled my poncho buddy for a second the first time he saw it....heehee
ID:	342500   Click image for larger version
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
The Following User Says Thank You to J.C.you For This Useful Post:
  #44
Old 11-09-2013, 08:50 PM
tpssonic's Avatar
Nice!
  #45
Old 11-11-2013, 02:39 AM
blueghoast's Avatar
Default 461 Stroker build.
Heres some more pics Tony.
GT.
ID:	342663   Click image for larger version
ID:	342664   Click image for larger version
ID:	342665   Click image for larger version
  #46
Old 11-11-2013, 11:51 AM
tpssonic's Avatar
Thanks, GT. Lookin' good!
  #47
Old 07-24-2015, 10:14 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Just wondering, anyone offering a 'service' to disguise AL heads ( D-port ) ? Dave at SD Performance isn't interested in this as a CNC program, but thought perhaps someone else was offering a service an aftermarket service.
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
  #48
Old 07-26-2015, 07:05 PM
boodlefoof boodlefoof is offline
Just for kicks I decided to put some casting marks on an Edelbrock Performer intake. I was bored and had a few hours to burn. I cleaned the intake really well and then used some quick set JB Weld to make the marks. I used a flat toothpick to apply the JB Weld. I mostly just took a blob and let it begin to drip and then guided the drip onto the manifold in roughly the shape I wanted. Then, as it began to cure just a bit I would use a clean toothpick to straighten it up and push the sagging edges back into place. Once the JB Weld was completely cured I used a Dremel with a 1/16'' drill bit to profile the numbers and letters by swiping the drill bit against the sides. I rounded off the edges just a bit with the Dremel and a small grinding stone.
I started running short on time, interest and JB Weld and left off the firing order marks that would go in front of the carb. I'm not trying to fool anyone anyway. Just having some fun.
Name:	water crossover 2.jpg
ID:	403810   Click image for larger version
Name:	intake small.jpg
ID:	403811   Click image for larger version
Name:	intake 4 small.jpg
  #49
Old 07-26-2015, 07:19 PM
Thumbs up Nice job!
Great detail work, I'm especially impressed with the date coding work on the water crossover.
Most folks would look at it and immediately think it's a factory intake.
  #50
Old 07-26-2015, 07:55 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
X2.. looks great!
  #51
Old 07-26-2015, 09:30 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Very nice!!
  #52
Old 07-26-2015, 09:53 PM
Gator67's Avatar
Gator67 Gator67 is offline
You may want to try Frank at AllPontiac. He had some Tiger Cub heads done up to look like 614s for my 70 Formula. He's also done 093s for our friends 66 GTO.
  #53
Old 07-27-2015, 02:13 PM
Thanks guys. I thought it turned out pretty well. If I can ever get this engine back together we will see how well the JB Weld holds up over time.
  #54
Old 07-28-2015, 08:52 AM
tpssonic's Avatar
boodlefoof- Mine (aluminum heads/intake) has been done 2 years and it looks as new. The engine has not been babied, either.
  #55
Old 01-01-2022, 01:18 PM
tempest1964's Avatar
tempest1964 tempest1964 is online now
Thought I would bring this back up. Came across this video online. Some very good tips on how to disguise your aluminum heads. Guy said he used to write for HPP. Never said his name. Don’t recognize his face. Good watch:
https://m.youtube.com/watch?v=0w4OlBbhNkY
The Following 3 Users Say Thank You to tempest1964 For This Useful Post:
  #56
Old 01-01-2022, 07:51 PM
Chris-Austria Chris-Austria is offline
Really creative guy!
I just removed the logos on the side and built a plate that bolts on to the front. which was painted like the rest of the heads to make them "stealth".
To remove the logos I used a belt sander and to make it a little rough again I used a sand blaster... looks really nice but empty
  #57
Old 01-01-2022, 08:15 PM
pastry_chef's Avatar
Last edited by Stuart; 01-01-2022 at 09:47 PM. Reason: removed unnecessary comments
  #58
Old 01-01-2022, 10:39 PM
Thanks Stuart
The Following User Says Thank You to tempest1964 For This Useful Post:
  #59
Old 01-01-2022, 11:54 PM
433lemans's Avatar
433lemans 433lemans is online now
Originally Posted by tempest1964 View Post
Thanks Stuart
Xtwo
The Following User Says Thank You to 433lemans For This Useful Post:
  #60
Old 01-02-2022, 12:19 AM
poncho447's Avatar
poncho447 poncho447 is offline
Thanks Stuart
Xthree...long overdue.
The Following User Says Thank You to poncho447 For This Useful Post:
