I was wondering if bigger battery cables are sold for specific cars and applications. I wanted a set made for my 69 GTO and a local shop made them but can one buy these already done, say for a 70's Firebird?
go to a welding supply store much better quality and price
Car Audio Shops also carry big heavy gauge cable up to 4/0 i think
It's hard to soar like an eagle, when you're surrounded by turkeys! My wife says she'd llike my car a lot more if it wasn't mine. ![]() ![]() ![]() ![]() 64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam. |
I've used these guys a few times, and they have an excellent product.
http://www.custombatterycables.com/ Industrial-quality lugs, different insulator material to meet different needs, and lots of options.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Welding cable carries more amps and has lower resistance than standard stranded copper wire of the same size. You can make your own pretty cheap. Most welding supply stores sell the cable by the foot and the ends too. I use marine style battery terminals and use size 01 cable.
Tim Corcoran |
I've had a problem with the insulation on the welding cable. While very pliable, it doesn't seem to last very long at all before rotting. The automotive rated insulation on battery cables seems to last forever.
Been awhile since I've bought per-assembled battery cables, but Blue Streak had some very nice stuff. Probably other manufacturers are out there as well.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
M&H Electrical will make you factory looking battery cables in larger gauges.
if you want something really good, most high end audio shops will have what you need
or that link to the custom battery cable, as i've read in the past others have had good results with |
You can go to any of the auto wire places and get the cable, and the spec is for a certain number of strands as well. Here is the DelCity offerings: http://www.delcity.net/store//store/Battery-Cable/p_351 Here's WayTek's offerings: http://www.waytekwire.com/products/1...Welding-Cable/ Even though WayTek offers some types of 'welding' cable, I personally would stick to the J1127 spec stuff. (even though it can cost 5 times as much) .
DelCity has a minimum of 25 feet and Waytekwire has a minimum of 100 feet so most guys won't want to buy 25 feet of battery cable.
I have had welding cable on one of my cars since 1985 and no signs of rotting or breakdown of the insulation. I also have welding cable on another car since 2005 and the insulation is like new. The insulation of welding cable is quite durable because it is made to be repeatedly drug around on the ground.
Tim Corcoran |
I have had welding cable on two different cars (one a battery in the trunk deal and one with the 67 RA battery cable next to the block deal vs thru the exhaust manifold.
Both look like new. Tom V. ps There IS different levels of welding cable too beside just gage size.
The welding cable that I've seen has a heavy rubbery cover that is larger than the PVC type cables, and it 'chunks' and dry rots/cracks. Because it's bigger in diameter, it's more difficult to route, and the standard retaining tabs are too small to work right. I had one at one time actually get 'mushy' and soft, like the cover was 'melting', and that was not from heat. (think it may have been from engine gunk/cleaner or brake/PS fluid)
There are places you can purchase the cable by foot, just have to shop it. The cost is pretty much the same as welding cable, so I really see no reason to not buy the properly rated and intended purpose cable for an auto application. .
Car Audio cable is manufactured much the same way as welding cable or locomotive cable, multiple tiny strands to make it more pliable. the advantage to car audio cable is it contains silicone for heat resistance. Keep in mind it is designed to be run to the battery, through the car to the trunk. 0 awg cable will carry up to almost 200 amps, 00 - 250 amps, and 000 - 300 amps, hence the reason most battery cables are #4 awg. Now, although if you put 4000W of stereo in your car, back it up with a couple of capacitors and beef up the alternator. as for standard, factory stereo stuff, your 145 amp alternator and #4 cable will be fine. Unless you are going from one end of the car to the other then, maybe, bump it to #2 gauge.
Good point, many go overkill on the starter cable when it's not needed, but keep in mind too that the battery charges over that wire, and depending on demand and wiring, you MIGHT need a larger one than 4.
IF you run the hot start 'fix' solenoid, and you use the post as a common junction for power, then you still don't need to upgrade the size of the actual battery or starter cable. (the starter circuit is isolated to the starter only) IF you run the OE wiring, and the charge wire goes to the starter, and splits to the horn relay, AND you have non-OE accessories, like electric fan, pump, stereo, then I would suggest going up one or two sizes. .
The #2 gauge cables (welding cable) I made in March 2006 look remarkably like they did when I put them on. They are made up of very fine copper wire, have a thin rubber covering and were/are amazingly flexible. After nearly 10 years can't imagine what would make that covering check, crack or chunk.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
Make your own.. It isn't hard And will be custom.. As custom can get..
http://www.ebay.com/itm/2-AWG-Gauge-...4hy76Q&vxp=mtr http://www.ebay.com/itm/2-AWG-Gauge-...BRydP9&vxp=mtr http://www.ebay.com/itm/20-2-GAUGE-2...YAAOSwDNdV2I0O
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
My point from the beginning is that if you are going to actually buy cable, why would you buy something that is not rated for under the hood of a car? Just makes no sense to me. .
FWIW RobbMC told me #4 was unacceptable for pushing their starters and I was having an issue with my cables so I went to a supply store and had them make me 1 Ott cables both positive and negative. Overkill on wire size never hurt anything but your pocketbook.
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
Mad Electrical also makes custom battery cables, and he's pretty reasonable.
MADelectrical.com
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote." ~Jack Handey, Deep Thoughts |
