| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Thanks a lot! It sure is a lot of fun! The build took forever it seems like and I get frustrated sometimes, but when I get to go for a drive it's all definitely worth it! Most of the time I just roll into the pedal and let off just to listen to the blow off valve! Lol
I just run 91-93 octane pump gas. Wich ever is at the station I stop at. I do have a Snow Performance water/ methanol system on it for when I want to run more boost, but I don't have that hooked up yet.
I'ts at between 9 and 10lbs now. Have to work on some traction to run any more. First gear is useless, and second gear will turn the car sideways most of the time. That's why all the videos are in second and third gear. The guys at work want a big burnout video so I'll probably be doing some more soon.[/QUOTE]
I have been working on traction. So far I've adjusted my bars, changed my worn out 28x13.50 Mickey Thompson ET Streets for my 30"x10.50 Hoosier slicks, and played with air pressure just a little bit. It's getting a lot better. I'm thinking of buying some Calvert Racing 9 way shocks and their leaf spring sliders to replace my Competition Engineering shocks and shackles. Anybody ever use this stuff? Any other suggestions? By the way I weighed it Sunday. It weighs 3,620lbs with me in there and five gallons of gas. Last edited by Boostedbird; 10-26-2015 at 09:23 PM. |
Please post your combo details sometime. I would be interested in reading it.
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
It's a 469". 455" 2 bolt block that's .040"over with a 4.25"crank.
90cc E heads that flow about 310 at my cams lift. Compression is 9.35:1 with .080" Comet head gasket Solid flat tappet cam 258-250@ .050", .605-.581" lift with 1.65 rockers, on a 114 Ported Victor intake and 850 CSU carb Homebuilt 2" 4 tube headers with 3" collectors and 3" crossover. TV8511 88mm turbo with 111mm turbine wheel and a 1.23a/r housing. 5" exhaust past transmission, then 4" to rear. Th400 with 4,600 TCI stall redone by PTC. 9" Ford rear with 3.89 gears and 30" Hoosier currently. Right at 10lbs of boost now. Tial 60mm wastegate Tial 50mm bov Extreme Velocity Pro hat with 4" up pipe. No intercooler. Locked out Hei with Msd BTM box, locked at 34 pulling 1 degree per pound for 24 at 10psi No ET's yet Last edited by Boostedbird; 10-27-2015 at 10:29 AM. |
A 3.89 is a lot of gear. Great vid.
Thanks Tom! Yeah, I want to change the gear to a 3.25 or 3.50 set if I keep 28" tires on it. That's why I put the 30" slicks on. Trying to kill some gear. With the 30's my final ratio is 3.37. I don't know if I like the way the 30's feel with swaying sometimes, so I may go with a 3.50 gear and 28's. I don't know yet, but I know that I do like driving it with a higher gear so far.
I'm going with a 3.60 and a 31" tire on my setup. I do have a 4 link and fairly wide tires.
I like to chart the tire, gear, rpm combo. Makes it easy to see where you really are. Looks like this. ---------------------------------------------------------- rear tire - 31" tall, 5843 multiplier rear gear 3.60 trans gears multiplier 1 2.33 0.01099 2 1.48 0.01731 3 1.00 0.02562 OD 0.778 0.03292 1 2 3 OD RPM | 8.388 | 5.328 | 3.600 | 2.801 | --------------------------------------------- 750 | 8.2 | | | | --------------------------------------------- 1000 | 11.0 | | | | --------------------------------------------- 1250 | 13.7 | | | | --------------------------------------------- 1500 | 16.5 | 26.0 | | | --------------------------------------------- 1750 | 19.2 | 30.3 | | | --------------------------------------------- 2000 | 22.0 | 34.6 | 51.2 | | --------------------------------------------- 2250 | 24.7 | 38.9 | 57.6 | 74.1 | --------------------------------------------- 2500 | 27.5 | 43.3 | 64.1 | 82.3 | ----------------------------------------------- 2600 = 86 mph cruise 2750 | 30.2 | 47.6 | 70.5 | 90.5 | --------------------------------------------- 3000 | 33.0 | 51.9 | 76.9 | 98.8 | --------------------------------------------- 3250 | 35.7 | 56.3 | 83.3 | 107.0 | --------------------------------------------- 3500 | 38.5 | 60.6 | 89.7 | 115.2 | --------------------------------------------- 3750 | 41.2 | 64.9 | 96.1 | 123.5 | --------------------------------------------- 4000 | 44.0 | 69.2 | 102.5 | 131.7 | --------------------------------------------- 4250 | 46.7 | 73.6 | 108.9 | 140.0 | --------------------------------------------- 4500 | 49.5 | 77.9 | 115.3 | 148.1 | --------------------------------------------- 4750 | 52.2 | 82.2 | 121.7 | | --------------------------------------------- 5000 | 55.0 | 86.6 | 128.1 | | --------------------------------------------- 5250 | 57.7 | 90.9 | 134.5 | | --------------------------------------------- 5500 | 60.4 | 95.2 | 140.1 | | --------------------------------------------- 5750 | 63.2 | 99.5 | 147.3 | | --------------------------------------------- 6000 | 65.9 | 103.9 | 153.7 | | --------------------------------------------- 6250 | 68.7 | 108.2 | 160.1 | | --------------------------------------------- |
Impressive work.
I appreciate it Junkyard! I am kind of proud of it. I've repaired header tubes and things before, but these are the first full set of headers and system that I've done. I like to just jump into things. Sometimes they turn out good, and sometimes not. Lol! I narrowed my stock fuel tank and used an old bbc oil pan for a sump for it. My buddies call it the Frankentank! I don't know if you can see it good or not, but I enjoy doing stuff like that.
Tom, that is a neat chart. I'll have to do some math to figure out what gear and tire to use. I've just been looking at other guys cars and of course using what I already have. By looking at your chart I may end up with 3.50's and the 30's, or something similar. Also, I'll have to go over to Yellowbullet.com and check on how your build is coming along. That thing is sweet!
Things are pretty static on my car. Lots of little nit's mostly right now. Limiters are done and in. Mid plate done and in. Turbo headers under construction. Its finally cooled down from the summer heat and progress will pick up significantly.
And I start back contract working in San Diego in three weeks and this time its for 24 months. |
Nice work!
Thank you! Watching the videos that you guys have been posting got me in the mood to do a couple little ones myself. How's your car coming along? |
