Old 11-08-2015, 11:05 PM
jusjay's Avatar
jusjay jusjay is offline
Default 1964 Pontiac Tempest
Moving in a different direction, too many project right now
$17,000 obo
Engine:
Block 75 YF 400
Stroked Kit Stroked crank, rods, and pistons, pins, and Bearings
Oil Pump 80 psi heavy duty oil pump formance
Heads Kauffman 85cc D-Port Aluminum Heads (flow 310cfm)
Lifters Comp Cams Hydraulic Roller lifters
Cam Schneider Racing Cams Hydraulic Roller -278-86RH
Rocker Arms 1:55 Roller Rockers
Timing Set JP Roll master
Push Rods Comp Cams Premium Chromoly
Intake Manifold Offenhauser 360 deg dual quad Modified to flow 290 cfm
Carburetors(s) 2x4 Edelblock Carter AFB's
Distributor Mallory Unilite
Gasket Kit Felpro Engine rebuild gasket kit
Starter Gear Reduction ROBB MC
Headers 4 into 1 Dougs
Fuel Lines Earls dual quad fuel lines
Linkage Earls dual quad progressive linkage
Carburetor Spacers Adapter plates for intake to AFB
Radiator Aluminum 2 core Radiator
Engine Machine Work Prep block for 461ci stroker kit 3.00' mains with 4.25' stroke D’Macs Automotive
Engine Assembly Assemble and perform engine break in D’Macs Automotive
Air Cleaners SD reproduction air cleaners
Rear Main Seal BOP Viton rear main seal
Alternator OEM style single wire
Valve Covers Custom Fab
Alternator bracket SD reproduction bracket
Flex plate TCI Street Strip R&B Total Performance
Transmission/Rear-end:
Transmission 86 BOP GNX 2004r ProTrans
Rear End GM 10.2 4pin 4.33 Posi
GM axles BOP 28 spline Transmission Rebuild Street/Strip rebuild
Stall ConverterNon Lockup 3500 Stall Continental unit
Auto Trans Shifter B&M Pro Ratchet Summit Racing
Electrical :
Electric fuel pump Holly Black fuel pump
Electric fuel pump relay
Battery Optima Red Top battery
Battery tray Battery relocation kit
Line Lock
Tachometer Auto Meter
Volt Meter Gauge Auto Meter
Oil Pressure gauge Auto Meter ng
Water Temp gauge Auto Meter cing
Transmission Cooler B&M
Cooling Fan Relay Painless Wiring
Chassis:
Trans Crossmember Fabricated
Rear Brakes Stainless Steel Brakes GM disc brake conversion kit
Master Cylinder GM dual 4 W/disc
Front Brake brackets Stock GM disc
front wheels 15x7 - front Cragar SS wheels for disc brakes
Front tires 670x15 Bias tire reproductions
Rear Wheels15x8 – rear Cragar wheels for disc brakes
Rear tires (slicks) 15x27x9.0 M/T Drag Radials
Misc. Braided lines
Body and Interior:
Seat Fabric Original fabrics SMS Auto Fabrics
Seat re-cover Beach Auto Interiors
Paint and misc:
Paint and Body Body work and paint Steele Rubber
Trunk Seal New Steele Rubber
Door seals - coupe New Steele Rubber
Cowl seal New Steele Rubber
Door vent window seals New Steele Rubber
Door and hood bumpers New Steele Rubber
Name:	64 pontiac1JPG.JPG
ID:	412704   Click image for larger version
ID:	412705   Click image for larger version
ID:	412706   Click image for larger version
ID:	412707   Click image for larger version
Old 11-13-2015, 02:06 PM
jusjay's Avatar
SOLD
