Old 11-18-2015, 07:16 PM
69FIREBIRD76MM's Avatar
Default my brother bought this olds with 455
It runs has very minor surface rust. What I like is the engine 455 with #16 heads.
ID:	413667   Click image for larger version
ID:	413668   Click image for larger version
ID:	413669   Click image for larger version
Old 11-20-2015, 01:52 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Could be `70, 16 small valve heads with press in studs. Check the date codes.
Old 11-20-2015, 07:41 PM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Check the engine code on the front passenger side of the block.
Andrew
IG: projectgattago
Please get in touch for Holley EFI tuning services.
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
Old 11-21-2015, 01:00 AM
I will do that.
Old 01-05-2016, 04:27 PM
Default pontiac powered olds
Got wheels for this now, heads are studded #16, 68-69. Motor sounds very healthy.
ID:	417454   Click image for larger version
