Old 12-26-2015, 10:11 PM
1966goat's Avatar
1966goat 1966goat is offline
Send a message via AIM to 1966goat Send a message via Skype™ to 1966goat
Default Stumbling & stalling off idle - bad gas?
This is for a SBC 350. Car runs fine on the highway and in park, but at a light she starts shaking a little, then off-idle she shuts off. She starts right up after. This happened mostly on some short hills.
Put in some seafoam and filled the tank with premium, she is running a little better, she stays alive but still stumbles. Should I add heet and change the fuel filter?
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust
Old 12-26-2015, 10:28 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
carbureted or injected?
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 12-26-2015, 11:34 PM
1966goat's Avatar
Carbed 1978 SBC 350.
Guy said car sat for 4 months without stabil.
Old 12-27-2015, 01:03 AM
77 TRASHCAN's Avatar
would it have an reel rock carb on it?
Shut it off
Shut it off
Old 12-27-2015, 07:14 AM
steve25 steve25 is online now
Time to tare the carb apart and clean the crap out from today's Ethenol cut fuel, gas tank additive will not fully help at times !
Old 12-27-2015, 08:55 AM
shaker455's Avatar
Get a carb kit like a Walker and go thru it.
Give it a good cleaning and use the new accel pump included
Record the stamped jet sizes and primary metering rods
Old 12-27-2015, 09:37 AM
suspect some plugs getting wet-fouled. Carb redo with idle enrichment may help close the Primaries.
