Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-28-2015, 02:34 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Default JE PISTONS 4.350 BORE
8 JE coated pistons for 4.350 bore , 1.200 cd ht . and 7 casidiam coated pins . Pistons ordered for first gen tiger heads . 350.00 plus shipping .
Name:	MK phone 12 28 500 (450x800).jpg
ID:	416752   Click image for larger version
Name:	MK phone 12 28 501 (450x800).jpg
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
Old 12-30-2015, 12:19 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Default Je Pistons
If I use a 4.50 stroke crankshaft what size rod will I need? Thank you
Darren.
Old 12-30-2015, 10:06 AM
It depends on deck ht to give exact length . With a deck ht of 10.200 for example rod length would be 6.750 . You would need custom rods .
Old 12-30-2015, 08:48 PM
Darren 639's Avatar
Default pistons
Hi Mike i am building a IA standard height block.I have the 4.5 crank I need to measure bore but i do think it will finish at 4.350 one more calculation to make is i bought don's RA5 heads so i need to see if valve relief is correct and compression will be with your piston. I will ask don to check on this for me i hope it works.
Old 12-30-2015, 10:39 PM
Don would know about valve spacing for tiger vs ra5 . Not sure if it will work , I know valve layout is different .
Old 01-05-2016, 07:06 PM
Bump
Old 01-12-2016, 11:37 AM
dci dci is offline
Hi Mike, When you get a chance give me a call.
Thanks,
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
Old 01-26-2016, 02:26 PM
Bump
Old 02-10-2016, 07:44 PM
TTT
Old 04-16-2016, 11:55 PM
Bump
Old 05-22-2017, 07:05 PM
TTT
Old 06-07-2017, 08:29 AM
Bump
Old 06-07-2017, 04:54 PM
Dragncar Dragncar is online now
What was the original intent. As in stroke and rod length ? Whats the dome ccs. Can they be used with E heads or HPs ? Why only 7 pins.
Old 06-07-2017, 06:51 PM
4.25 stroke , 6.900 rod ( depending on deck ht.) , flat tops , broke a rod and threw piston and pin away .
Old 06-07-2017, 08:57 PM
racegto65's Avatar
racegto65 racegto65 is offline
Mike I'm interested but was wondering if you could measure them.
I have a block already at 4.350 and need to know what the wall
clearance will be.
Thanks.
Old 06-07-2017, 11:22 PM
Ok , I will try and measure tomorrow and post.
Old 06-08-2017, 05:11 PM
Have some 6.875 Crower billets. Would work but piston would be .025 in the hole right ?
Old 06-08-2017, 06:07 PM
Need to know deck ht to tell for sure .
Old 06-25-2017, 06:32 AM
Sold
