Old 01-02-2016, 05:34 PM
BOB VIDAN BOB VIDAN is online now
Default 65 66 Low Fuel Warning ????
I thought low fuel warning was only available speed minder alert. Right or wrong? I have a lfw setup I recently pulled and there is not sma.
Practicing social distancing for 65+ years
Old 01-02-2016, 06:03 PM
bill ryder's Avatar
bill ryder bill ryder is online now
TOOO many acronyms for me!!!!! LOL. "Bill"!
Old 01-02-2016, 10:10 PM
GT182's Avatar
GT182 GT182 is offline
Bill, it's West Coast code. Or Bob's still hung over from New Years. LOL
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 01-10-2016, 03:24 AM
I do have a lot of trouble communicating with "certain" people in the Carmi, Il area, my bad.
Old 01-10-2016, 11:47 AM
orejudge orejudge is offline
Bob, try crms, or detq maybe even bgyu hope that helps.
Old 01-10-2016, 12:28 PM
And some people in Bend, Or.
Old 01-10-2016, 02:58 PM
marxjunk marxjunk is offline
speed warning comes with low fuel...
if theres a low fuel it just probably means someone stuck it in there and probably didnt realize it was a low fuel gauge....or...its a speed warning piece and some one stole the speedo not knowing the low fuel was part of the package..or the speedo failed and they threw what was available in there
fuel gauge will work with no power to the light
if there is a sticker on the gauge it would be what id use to decode which cluster it was originally
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 01-10-2016, 07:35 PM
Finally, another human. Mark, I'll take a look at it and see what's there.
Old 01-10-2016, 08:11 PM
the low fuel light is a little black bolt on pod, it has some really thin wires that run to that fuel thingy on the gauges that is a red piece of circuit board and is wound for resistance for the gauge to read ohms....when the resistance get right.( i cant remember which way ) the light comes on..
the pod is like 3/4 by 1 inch and has a round circuit board in it and a bulb
at least thats what i have seen on the early cars...as technology got better the pod went away..
i just found this pic on ebay...its a 71...i thought the pod went away by 69 but guess later...the metal rectangular thing/relay is the buzzer..you wont see the buzzer on an early car..its screwed to the brake hanger and if i remember right its pink and weird green wires..
the low fuel thing is the black plastic thing with the green and red wire...if this is there..its functional..it is in fact what makes the lamp light up..its very similar to what the early cars have...like i said ive had a bunch of 67s...
thinking back...i think 66 or 67 was the first year for speed warning and low fuel in a lemans, not 65..it coincides with the map light mirror thing on the roof rails..pontiac started throwing big car like options on lemans' because they sold well
it would take some research to know when it started..and i really think 67...because it was first avail in a skylark in 67..i have one...not 66...
Mark..
The Goat whisperer
Old 01-10-2016, 10:39 PM
Mark, this is kind of interesting. The number on the gas gauge is for low fuel warning, 0375. My 67 master parts book says 65 - 67 had speed alert, which would include low fuel warning, and park brake light. If you look close at the back of the speedo, there's a small key hole not on other standard gauges I have. Also this cluster is XS and the others I have are WA. At one time I did have a lens with the hole for the speed alert setting, now I know where it came from. Last picture is from 66 option/accessory catalog.
ID:	417862   Click image for larger version
ID:	417863   Click image for larger version
ID:	417864   Click image for larger version
ID:	417865   Click image for larger version
Old 01-11-2016, 12:37 PM
hmmm...i cant recall ever seeing one in a 65 a-body
i thought 66 or 67..but for some reason stuck on 67..but its good your going in the right direction...
Mark..
The Goat whisperer
Old 01-15-2016, 06:04 PM
Option 382's Avatar
Option 382 Option 382 is offline
The low fuel warning lamp and safeguard speed come together as a package on the 1965 year as option 634. However you could NOT get this option with the Rally instrument cluster.
