Old 01-30-2016, 10:43 PM
Geez, I am amazed that all of those experts on Speedtalk, for the most part agree with my post # 1036.
One of the posters on the Topic, TUNER, is a very good carb and induction guy.
We have had a lot of discussions, into the night, on how carbs and induction systems really work. It is too bad he is so far away on the left coast.
The "river" running into the runners can be fuel or even water in some cases.
We have lots of "camera in the intake" video on that fuel and or water "river" and how it migrates to the given cylinders.
  #1042
Old 01-30-2016, 10:47 PM
tom s tom s is offline
Tom,did Jon deal make sense?He is a very sharp guy.Tom
  #1043
Old 02-05-2016, 11:13 PM
Ron H's Avatar
Ron H Ron H is offline
Originally Posted by dci View Post
I thought everyone might like to see a little eye candy today!!!!! These are JC's DCI RA5 heads and intake mocked up on another customers aluminum block.
Sweet Pontiac porn batman, Grats Don, looks awesome. Love the vids. Hot for DCI RAV's, my new favorite Halen video!
68 Firebird
Are you running with the wind or breaking it?
  #1044
Old 02-06-2016, 12:25 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Tom,
Can you explain the normally aspirated results we're seeing in the video referenced video from your point of view in layman terms, I'm not sure I understand what you are saying.
Thanks,
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1045
Old 02-06-2016, 01:03 PM
dci dci is offline
I have had allot of guy's asking what the difference is between my heads, the factory heads, and Lynn's heads. So I took a few pic's with them side by side so that everyone has a visual. My head is the taller of the three in the pic's. My head also resembles more of the factory heads aesthetics or appearance. I wanted my heads to look more like a factory head than an aftermarket piece. Note that the factory heads have a tear drop exhaust port configuration. The lower portion of the factory exhaust ports is basically dead space and does not help flow. I'm not sure why they did it that way. I cast the pushrod tubes into the heads and brought the leading edge of the tube to the intake surface. I done this so the tube can be stream lined to reduce turbulence and help the air get around the tube. This can be configured in a couple of different ways depending on what your philosophy about port taper is. I have ported some with the leading edge starting at the intake surface and some with a wing in the intake and interfacing it to the tube. We don't know for sure yet which is best. We will have more data after we get several different combo's together and dynoed.
ID:	420113   Click image for larger version
ID:	420114   Click image for larger version
ID:	420115   Click image for larger version
ID:	420116   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #1046
Old 02-06-2016, 01:05 PM
dci dci is offline
Here are a few more pic's.
ID:	420118   Click image for larger version
ID:	420119   Click image for larger version
ID:	420120   Click image for larger version
ID:	420121   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1047
Old 02-06-2016, 01:07 PM
dci dci is offline
Some more !!!!
ID:	420123   Click image for larger version
ID:	420124   Click image for larger version
ID:	420125   Click image for larger version
ID:	420126   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1048
Old 02-06-2016, 01:09 PM
dci dci is offline
And a couple more !!!
ID:	420128   Click image for larger version
ID:	420129   Click image for larger version
ID:	420130   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1049
Old 02-06-2016, 01:38 PM
GTOGEORGE's Avatar
Great pics..........very helpful!
GTO George
  #1050
Old 02-06-2016, 01:58 PM
Tube in a port is not a great idea (see picture attached)
You get all kinds of unwanted Turbulence and flow losses in the port from that design.
"Split Port" design like Don (DCI) has in his head is a better design.
Name:	airflow around a tube.png
  #1051
Old 02-06-2016, 06:46 PM
dci dci is offline
Thanks Tom for the chart. Here is a link to another visual of fluid dynamics with different shapes and their effects.
https://www.youtube.com/watch?v=q_eMQvDoDWk
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1052
Old 02-06-2016, 07:22 PM
dci dci is offline
Here is another short video of why dimples help golf balls fly further. This same technology can be used in cylinder heads to help atomize fuel and create less drag.
https://www.youtube.com/watch?v=LvVuuaqCC7A
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1053
Old 02-06-2016, 07:27 PM
dci dci is offline
Here is another one. If you guy's haven't guessed yet. I spend allot of time researching fluid dynamics and air flow LOL.
https://www.youtube.com/watch?v=GHOoZYhF6r4
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1054
Old 02-06-2016, 08:20 PM
sdbob sdbob is online now
Remember few yrs ago we talked about that. You showed me some samples from someone did. I thought afterwards if it worked why hasn't it been used before?
  #1055
Old 02-06-2016, 08:32 PM
Guys,want to bring up to speed on the dyno build.Don and I have been in contact.As of this time there is no build or dyno time avail.Joe has a few engines ahead.Im going in for shoulder surgery the 24th of the month and will be out of action for awhile.if things work out and no one has got a N/A DCI headed street engine on the dyno im still game to do it.Wish me luck on the shoulder.Tom
  #1056
Old 02-06-2016, 08:51 PM
455firebird1969's Avatar
Good stuff Don. Similar YouTube videos (ancient) were used by my aerodynamics instructor. I seem to recall the golf ball in flight is experiencing "Magnus lift" a lifting force experienced by rotating bodies, and the dimples reducing drag. I wonder if race car wings will ever incorporate "Winglets" to reduce induced drag?
  #1057
Old 02-08-2016, 12:31 PM
dci dci is offline
I get asked that allot LOL. I think because there is not a lot of guy's doing it yet or have experimented with it yet you just don't hear about it. Aeronautics, NASA, Formula 1, and other industries are using this technology. It just has not trickled down to us neophytes in the hot rod world yet.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #1058
Old 02-09-2016, 01:45 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Be nice if you could dimple the pushrod split and see if it makes a difference on the bench.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #1059
Old 02-09-2016, 05:31 PM
Cool
Wishing the Pushrod "tube" was a wing Trailing edge for air coming and going.
  #1060
Old 02-09-2016, 06:13 PM
dci dci is offline
That can be done. There is plenty of material to shape it any way you like. What we have found it likes on the flow bench. Is a shape close to an airplane wing. Kind of like a tear drop, but with more of a pointed leading edge. The more I play with the shape the more I learn. You can definitely hear it on the bench when it doesn't like the shape though. I think this is going to be a neet tuning tool once we get a handle on what engine likes.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
