Old 08-30-2012, 09:02 PM
64woodwheel's Avatar
64woodwheel 64woodwheel is offline
Default 64 Tri Power Engine Cutaway View
Found this on HPP's site.
Here is a direct link to see full size. Click on picture after it opens.
http://image.highperformancepontiac....ent+engine.jpg
Old 08-30-2012, 09:06 PM
Very nicely detailed, even has the cut and welded throttle cable bracket.
Old 08-30-2012, 09:30 PM
GT182's Avatar
GT182 GT182 is online now
Now that is art, what a talent he has. David needs to have prints made up to sell... and they'd sell like hotcakes too.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-30-2012, 09:57 PM
John V. John V. is offline
I'm blown away by the artistic talent cause I have none.
But just to pick nits, there is a typo on the starter motor, should be 1107294.
And I think there is a detailing error on the fan clutch, missing the two "blocks".
But jeez, I have trouble staying within the lines in a coloring book, that is pretty awesome work.
Wonder who owns the motor that was used for the modeling gigl? I envy that guy too.
Old 08-30-2012, 10:14 PM
I'm with John.
I couldn't draw a straight line with a ruler.
HO Racing has one for the SD 455 that is actual size.
But it is a line drawing, not like a picture or real look.
I'd say David Kimble is the artist.
Is he on PY?
Old 08-31-2012, 08:16 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Thumbs up 66 Tri-Power Unit
The above 64 motor is awesome art!
Here is an impressive pencil sketch done by Shawn Hardgrove.
Name:	Pencil Sketch - Shawn Hardgrove.jpg
Old 08-31-2012, 08:24 AM
Keith Seymore's Avatar
As an aside, I have worked with David Kimble to create this type of art (for Chevy Truck sales brochures and presentations).
He takes the math data (aka electronic engineering drawings) and his own photographs and melds them into the incredible artwork you see here.
He is very talented and is a quiet, humble man and a joy to work with.
Thanks for posting that, Chad.
K
'63 LeMans Convertible
'63 Grand Prix
Old 08-31-2012, 10:56 AM
bigpop bigpop is offline
That fellow really has an eye,wow! Very informative and beautiful, at the same time, awesome talent. Larry Banks
Mr. President, you can't say Dallas doesn't love you "
Old 08-31-2012, 01:11 PM
dlarkins's Avatar
dlarkins dlarkins is offline
AWESOME !
'65 GTO Hardtop
389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes
"What's the point of owning a muscle car if you can't scare yourself stupid from time to time ?"
Old 08-31-2012, 11:58 PM
Tenney Tenney is offline
Cool, thanks!
Old 09-01-2012, 09:05 AM
Link to more of his work:
David Kimble
Lots of cool works.
Old 09-01-2012, 07:53 PM
bill ryder's Avatar
bill ryder bill ryder is offline
John V. I'm a little behind. What "blocks" are you referring to? My car is in the trailer and I haven't seen it for a month!!!
On the plus side, I have been looking for what I thought was a "correct" clutch for my car for more than a year. The clutch portrayed is what I have, soooo, guess I'll stop looking. My clutch does not have a date code, but does have PF. Seems like we had a thread and PE and PF were correct??? bill
Old 09-02-2012, 12:09 AM
tripwr1964's Avatar
tripwr1964 tripwr1964 is offline
ahh, that's my new wallpaper! cool
Old 09-02-2012, 02:06 PM
bill ryder's Avatar
John, I couldn't stand it!! Had to go look. Those "blocks", are they the 3 areas in the aluminum fins on the front side that there are no fins??? bill
Old 09-02-2012, 04:14 PM
60sstuff's Avatar
Smile Additional pick nit?
I too have made this my desktop backround! Even the OEM screens that support the foam air filters is cool! Just an observation but I don't think the end carb outer pump rods used the clips at each end as the rods stay in place on their own?
Old 09-02-2012, 08:59 PM
60sstuff's Avatar
Red face Dah,
Not exactly as I said above, as there are U shaped clips that crimp closed around the groove in both ends of rods opposed to the clips shown in the cutaway art.
Old 09-03-2012, 04:34 PM
Dick Boneske's Avatar
I noticed the rear carb is a "997" and the front is a "683". I don't know if this was done intentionally, but look at the pictures I've attached.
Only the "683" carb bodies I have are without the hole in the choke cam boss--first picture. The second picture is of a late "997" carb body which has the shorter choke cam boss, but a tapped hole where the choke cam screw is located on a center carb. The last picture is of an early "997" carb which has a longer cam boss, different reinforcment casting, and casting numbers under the bowl instead of on the side.
Name:	Old vs. Newer Tripower Carb Bodies 007.jpg
ID:	421322   Click image for larger version
Name:	Old vs. Newer Tripower Carb Bodies 006.jpg
ID:	421323   Click image for larger version
Name:	Old vs. Newer Tripower Carb Bodies 005.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-03-2012, 04:56 PM
Bill, yes. But now I'm a bit confused, I thought 2 "blocks" on a '64 Eaton fan clutch, are there 3? I don't have an original '64 fan clutch.
Old 09-03-2012, 05:37 PM
Here is a screen shot of a dealer training video that shows the steel 7 blade fan. There are 2 blocks or areas void of fins, at about 2:00 and 8:00. It appears to be flat black. There are some stamps on the clutch, but I cant make them out. Here is a link to the video, fan blade is at 10:31. The clutch is mounted on the wrong side of the fan, makes the blades look backward.
http://www.youtube.com/watch?v=MptrM...&feature=g-upl
Old 09-03-2012, 08:14 PM
bill ryder's Avatar
I did agree with Chad. That is why I've been looking for a fan clutch for several years. BUT, now that I have seen this wonderful rendition of a "64 TP engine, complete with natural dip stick, I'm not so sure. The clutch I have always had is EXACTLY like the one David Kimble has reproduced, minus the "blocks", so where would he have seen the clutch he drew if not on the '64 engine he drew???
John, my clutch has 3 "blocks at 120 degrees and PF stamped on the front, but no date code. Think I'll slow down looking for a clutch and just listen and learn. bill
