Old 03-13-2016, 01:57 PM
dataway's Avatar
dataway dataway is offline
Save those photos that look like original OEM stuff ... more help for the community looking for how things were done at the factory.
Old 03-13-2016, 05:39 PM
nytrainer's Avatar
nytrainer nytrainer is online now
Nice project but I'll request posted pics and specs of your new shop too now that I plan on subscribing to your build thread and living vicariously through you
Old 03-19-2016, 01:19 AM
Go-Tee-O Go-Tee-O is offline
Still has both 2-piece brake rotors. Haven't mic'd them.
Also has the uber-rare 4-lug option!
69 GTO in progress | 72 Chevy C10 Highlander | 06 Honda VF800 Interceptor | 96 Honda XR250R |
Old 03-19-2016, 01:20 AM
Was hoping the 4-row radiator might be usable.....perhaps not.
Old 03-19-2016, 01:22 AM
If you look closely, it still has the spiral shocks on the front. And they seem to work!
Old 03-19-2016, 01:23 AM
I guess these are replacement shocks on the rear?
Also, apparently someone couldn't afford a $5 pack of coil spring spacers at Kragen, lol!
Old 03-19-2016, 02:26 AM
Ha, I'm usually the one living vicariously! But since you asked, the shop is 24x36. Kia included for reference
Old 03-19-2016, 04:32 AM
dataway's Avatar
A good radiator shop can do amazing things with old OEM parts ... don't throw that radiator out.
That wood in the spring is an old trick .... it was probably running NASCAR with a minimum height spec ....the wood holds the car up to pass over the inspection block, then the wood pounds out on the high banks and drops the car down That's my story and I'm sticking with it
Old 03-19-2016, 04:34 AM
dataway's Avatar
I think that is a nice shop .. mine is only 24x32 ...but, under the house, so stays pretty warm and is easy to get to.
Old 03-22-2016, 09:11 AM
71 T/A 71 T/A is offline
Oh, as far as color, I don't plan on going back to the Expresso Brown. I'm kind of partial to Liberty Blue, possibly Crystal Turquoise. In any case, the vinyl top is out.
My 69 GTO came Espresso Brown and I painted it Burgundy, which looks great. Never went back to the vinyl top, a rust magnet for sure.
Old 03-23-2016, 10:42 PM
Nocar's Avatar
Nocar Nocar is offline
Keep the vinyl and like the 428!
1966 GTO
Isaiah 6:8
Old 04-12-2016, 11:05 PM
Default Little progress....
Got the hood off, hood hinges, and the trashed windshield. I knew there were some holes in the driver's side A-pillar. Looks good at the roof. Some rust on the top of the dash, not the worst I've seen.
ID:	426193   Click image for larger version
ID:	426194   Click image for larger version
Old 04-12-2016, 11:16 PM
If you look closely, you can see the skin of rust that formed on top of the water that sat in the some of the intake ports. Might be a clue as to why the engine won't rotate, lol.
I'll be glad to get all the orange-rusty stuff out of the engine compartment.
Name:	intake port_small.jpg
ID:	426196   Click image for larger version
Name:	engine compartment_small.jpg
Old 04-26-2016, 12:30 AM
Got the front end off. Not too many surprises.
Whoever said that California cars don't rust??
Most important tool, lol
Just a little bondo.
ID:	427064   Click image for larger version
ID:	427065   Click image for larger version
ID:	427066   Click image for larger version
ID:	427067   Click image for larger version
Old 04-26-2016, 12:38 AM
*facepalm*
Should have built a bigger shop
Name:	oil filter.jpg
ID:	427069   Click image for larger version
Old 05-14-2016, 10:56 PM
Default More progress...
Front end coming apart
Still has the spiral shocks on the front, and they still work!
One of the spring tags survived, as well. This car is a real mix of OE and OMG
Name:	spiral shocks.jpg
ID:	428437   Click image for larger version
Old 05-14-2016, 11:02 PM
Got the engine and trans out today.
Frame is solid.
Frozen XH 400. Trans had decent looking juice in it. Distributor won't budge :/
What's better than a JC Whitney replacement expansion plug?
A JC Whitney plug that's oh-so-close to possibly shorting out the battery cable!
Hopefully will get the 428 block on the stand tomorrow and start building.
ID:	428443   Click image for larger version
ID:	428444   Click image for larger version
ID:	428445   Click image for larger version
  #38
Old 05-15-2016, 04:57 AM
dataway's Avatar
Very cool stuff ... pain in the butt yes, but very cool to see some original stuff like that.
  #39
Old 05-15-2016, 10:50 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
OE and OMG, to funny! Looks like you might be lucky to even have this car with that JC Whitney deal.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #40
Old 05-16-2016, 12:11 PM
OE and OMG is going into my permanent lexicon!! What a flawless way to describe that kind of car we've all come across in our wrench turning lives!!
It brings back memories of a similar 69 GTO I had in the 80's...
We called the guy I bought it from Goofy:
a 76 400 (factory dished pistons to get to 7.6 to 1) with a set of 76 455 heads to net about 6 to 1 compression
a square bore holley on a factory spreadbore intake which resulted in a somewhat limited throttle opening!!
I guess to compensate for those two problems he upped the gear ratio, only problem was that he only changed the ring gear not the pinion gear! a tad noisy and more metal shreds in the diff than oil
valence, fenders, rad support were all one welded together unit, luckily he couldnt weld so a tap of a hammer and the welds all let go
and finally this car had a special way to find itself back home... just like Hansel and Gretel it started dropping oil pan bolts driving it home followed by ever growing oil drippings.
