73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 03-23-2016, 08:08 PM
73Grand 73Grand is offline
Default How to install trunk lock
Trying to put in new trunk lock and I can see how the "clip" that goes through the bottom of the lid secures the lock but I can't get them to lock together while trying to install in the lid. Any tips? Thanks
Old 03-23-2016, 10:07 PM
They are a bit of a pain but when you push the lock plate up it has to catch the lock cylinder at the ridge just right. It will take more then a few tries, at least it did for me. Just keep at it. I forgot to add that the lock goes in through the lock bracket or the holder or lock that holds it in. The lock needs to go in the trunk lid while the Lets call it the holder,, is in but not pushed all the way up. It will be about 80% in & then while the lock cylinder is in you push up as the lock cylinder has to catch the lock cylinder as you push up. It looks like its a key slot, the big end & when you push up it goes into the small end of the holder. When you look at the holder you will see how the hole the lock cylinder is shaped. The big end is where the look cylinder goes through & then you push up it will catch the tabs on the cylinder to lock it in.
Old 03-26-2016, 07:04 PM
That's what I've been trying to do, guess I'll just have to keep doing it over and over.
Old 03-27-2016, 11:39 AM
77 Canamman's Avatar
They have gone together easy for me. Once the clip is in place, the clip is riveted to the trunk lid.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
