Old 04-08-2016, 08:24 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Cool build.
What compression?
Old 04-08-2016, 09:10 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
10.84 comp.
Old 04-08-2016, 09:44 PM
77 TRASHCAN's Avatar
Can't wait to hear what Continental recommends for a converter. That should be an interesting conversation...you've got a 571 Pontiac?
Shut it off
Shut it off
Old 04-08-2016, 09:48 PM
71 T/A 71 T/A is offline
Doesn't everyone? Lol!
Old 04-08-2016, 10:09 PM
Hooter's Avatar
Hooter Hooter is offline
Sweet build. Same shortblock as in my 65. Gotta love the torque of the 4.75 arm.
67 Bonneville ragtop
Old 04-08-2016, 10:11 PM
That 571 would be an ideal candidate for a 3.25 or even a bit taller gear.
Mountains of torque.
Old 04-08-2016, 10:39 PM
GTO JONES's Avatar
I was thinking of a 3.50, I like the 3.25 idea, don't know how it would act on the low end.
Old 04-08-2016, 10:45 PM
You probably wouldn't see any difference in track performance between a 3.50 and a 3.25 gear.
Much more enjoyable on long drives with a taller gear, that 571 would easily tug a 2.75 and still tear your head off.
Old 04-08-2016, 11:15 PM
GTO JONES's Avatar
I plan on driving it more, I'm going to retire and move to Arizona real soon.
Old 04-09-2016, 12:31 AM
BB70's Avatar
BB70 BB70 is offline
You could put that in the Ohio river & pull barges around with it!
Are we going to see it at Krogers in Milford again before you leave ?
John
Old 04-09-2016, 07:04 AM
Links to the Dyno pull pdf's:
571 PULL NO. 2 SHT. 1 OF 4.pdf
571 PULL NO. 2 SHT. 3 OF 4.pdf
571 PULL NO. 2 SHT. 4 OF 4.pdf
571 PULL NO. 3 SHT. 1 OF 4.pdf
571 PULL NO. 3 SHT. 3 OF 4.pdf
571 PULL NO. 3 SHT. 4 OF 4.pdf
Larry wrote:
Here are some of the pulls and their corresponding sheets with other data. First 3 are one of the 2 dominators used. Last 3 is a 4150 950hp. There were a few dozen pulls on it trying all kinds of things but these are the ones where they were happy with a conservative pump gas tune. Ended up with a 2” super sucker on some of the last pulls and the engine loved it.
Old 04-09-2016, 08:23 AM
GTO JONES's Avatar
Oh yeah, it will be there....lol
Old 04-09-2016, 12:28 PM
My father said the dyno sheets showed up.
Thanks for doing that John, much appreciated.
Old 04-09-2016, 01:08 PM
gtofreek's Avatar
gtofreek gtofreek is offline
John
So what are you saying? His car is a boat? LOL!
Great job Jones'!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-09-2016, 01:15 PM
Will Will is offline
Dang. That's a big motor!
I bet you could put 3.08s out back and it would be plenty fast and an absolute blast to drive on the freeway.
Old 04-09-2016, 01:45 PM
Fully agree.
Here's thread featuring a car that surely weighs in very close to the '69 GTO that is the subject of this thread, running solid 11.40s (best run 11.3893 at 120.63 MPH with a 1.6802 60ft) with 109 less cubes and about 150 less HP using a 3.08 gear:
http://forums.maxperformanceinc.com/...highlight=3.08
I wouldn't hesitate to run a gear somewhere between 3.00 and 3.25 (Ford 9"), leaning towards the taller gears.
No need to spin that big 4.75" stroke excessively while enjoying a long drive, I'd be willing to give up a tenth or two at the track to enjoy a lot of cruising into the sunset during my retirement.
Old 04-09-2016, 02:06 PM
Formulas's Avatar
Formulas Formulas is offline
Nice build...for a mostly street cruise car I would be inclined to have continental build a tight enough converter to let the engine idle then couple up quick after idle..
My reasoning is even at 1500 RPM that engine is probably out torqueing most engines at their peak and it wont stay at 1500 RPM very long with that torque.
2.50`s or 2.70`s gear out back, gears multiply torque, how much do ya need at the tires..
These two things would make it seem like a mellow stock car at part throttle and putting around will make the engine last longer and then when the hammer is dropped I would be willing to bet not much would be lost from a 3000 stall and 3.20 gear
Probably hook a lot more street racers telling them you have a 2.50 gear and stock converter If that's your thing
  #38
Old 04-09-2016, 06:44 PM
GTO JONES's Avatar
Yeah, I agree I lean toward the 3.25 right now with a tight conv. (better gas mileage too) lol. It came with a 3.23 when it was new.
  #39
Old 04-09-2016, 09:16 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
very cool car!
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
  #40
Old 04-09-2016, 09:29 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
If you are cruising it alot you will like the 3.08's. Very nice build and good luck.
Steve
