SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
Blueprinted Melling Pontiac Oil Pumps, New
Brand new blueprinted Melling 80psi oil pumps with new billet drive shaft. All from Precision Oil Pumps - two available, $110 shipped
Product Description Precision Oil Pumps Blueprinted Melling 10541. Fits all Pontiac 350,389,400,428,455 engines. MELLING HIGH-VOLUME BLUEPRINTED OIL PUMP.The pump is a brand new Melling HV / 80PSI 10541 PONTIAC SUPER-DUTY Race pump. Fits all Pontiacs 350,389,400,428,455 engines. Each pump is disassembled in groups of ten, passages are radiused and blended by hand, the mounting surface is machined flat. Housings & Gears are then Deburred by a vibratory polisher then cleaned. The Gears are then sprayed with TECH-LINE moly-coating and oven cured, then reassembled to precise tolerances by using a gear set with the correct clearance, The relief check-ball valve is cleaned and is re-installed with the existing spring & new hardware, Each cover plate is fastened with safety-wired aircraft bolts. All pumps are bench tested. In addition, all pontiac race pumps come with our 1/4" HD cover plate for a better seal and added strength and also features a oiling hole in the center pilot gear which pressurizes oil to the center shaft. Buy with confidence.
'71 GT37 9.75/136 474 w/#62 D-ports from SD |
why just a 80psi pump?
Not sure what you're asking. Precision Oil Pumps offers them in 60psi and 80psi, race and standard config depending on the work done on them. They include a new billet drive shaft and gasket. I usually use ARP studs which I would have included but didn't have any extra.
Thanks for looking
i will take one. paypal ok?
PM sent
resend it, didn't get anything
I will take the other one. Let me know how you want payment.
Oil pump
I'm in for one
SOLD - Thanks PY and to the members
