Old 05-02-2016, 08:29 AM
grandville455's Avatar
Default New Best
Set a personal best on sat at the Rock, Track is still green cause its new, but once a little sun came out later on, and they dragged it and sprayed it came around briefly, and I made 4 great passes with 60fts all 1.42-1.43, That's still leaving at only 2500 on the FB,The weather was cool, 58 degrees? Hum was around 40%, But there was a terrible headwind , gusting over 20+.
I was very pleased with it, Shifting at about 6200, thru the traps about 6550 and I think it shows great promise that there is plenty left in it!
Darby
M/T 275/60 ET SS Drag Radial
Old 05-02-2016, 08:58 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Great job!
Go fast, see Elvis!
Old 05-02-2016, 09:10 AM
Curious George's Avatar
Curious George Curious George is offline
Awesome!
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 05-02-2016, 09:33 AM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
Would you quit it. I keep trying to catch you, but you keep going faster.
Less said,,,,,,,, Less mended.
Old 05-02-2016, 09:37 AM
ta man ta man is offline
Awesome..getting closer!
Old 05-02-2016, 09:44 AM
77 TRASHCAN's Avatar
Ernie,
When's your next trip to track? W/ Andy? Hope Chris can go soon also!
Tres Poncho's
Shut it off
Shut it off
Old 05-02-2016, 09:57 AM
gkinch's Avatar
gkinch gkinch is offline
great job Darby! that thing is hauling a--!
Gene Kinch
1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116
1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108
1971 GTO 400,t400 3.23 10 bolt all original 14.41@96
1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85
1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction)
1979 TA, 400/ 4 speed all original needs restoration.
1999 Trans Am LS1
Old 05-02-2016, 10:20 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Darby-
Did you make any changes over the winter?
Old 05-02-2016, 10:27 AM
Thanks Guys!
Tininjun, sorry cant stop now
John, I changed my emulsion package in my dominator, Went from the 2 like a stock holley location and went to 3 with alot smaller holes, but still the same in area as my 2 were. I also went to a msd dist with one spring off the advance trying 30 total instead of the 26-27 i ran on the dyno and all of last year. Im guessing u factor out the wind i picked up a solid tenth maybe more. I'm still on old tires too.
Darby
Old 05-02-2016, 11:29 AM
Scott Stoneburg's Avatar
Awesome job. Keep tuning.
Old 05-02-2016, 11:50 AM
torqjunki's Avatar
torqjunki torqjunki is offline
Nice job Darby! Been wondering what you were up to. Didn't doubt you would be posting up a new best. Prob been asked before, but what converter you running?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
Old 05-02-2016, 12:23 PM
Thanks! I'm always up to something . Running UCC 9" 48-5000 flash stall..
Darby
Old 05-02-2016, 12:42 PM
Good job!
Old 05-02-2016, 02:28 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Nice job Darby. Jake & I were both there. You were busy talking to the woman when we came by the car. It sounded like you were on the brake??
Brian
Boobs & bacon
Old 05-02-2016, 03:00 PM
Ernie,
Tres Poncho's
I'm planning in 2 weeks testing a new intake ported by a fellow board member...I know Andy went through a rather extensive rebuild and is getting really close...Chris is pretty well ready too....I know us 3 aren't your typical hardcore dragracers...but we live and die by the timeslip too!
Old 05-02-2016, 03:11 PM
Brian
That was u guys? Dammit ,lol... No brake, just a two step wired so i can foot brake it.
Darby
Old 05-02-2016, 04:51 PM
stroker461's Avatar
stroker461 stroker461 is offline
Congrats Darby, I predict we'll see 9's in the near future!!!!!
Old 05-02-2016, 05:23 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Nice run. Where do you think you have more, the 60 foot?
Old 05-02-2016, 05:58 PM
60ft, and the whole run, the wind was definitely holding me back up top, a friend was down 2 mph in his low 10 nova. I didn't even get to try my Wilson spacer etc.
Darby
Old 05-02-2016, 06:15 PM
Great improvement and as you posted still more there. The 60 ft times are coming around for you.
Keep up the good work. Beginning of the season!
