Old 05-11-2016, 04:09 PM
Pontiac Derek Pontiac Derek is offline
Thanks for the Compliment Darby.
Hopefully the Dyno Results i get Translate into Quicker ET's
No Easy Feat in a Heavy,Low RPM, Tall Geared Street Car!!!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #162
Old 05-11-2016, 05:50 PM
ta man ta man is offline
I knew someone would figure out who did the port work.Darby has a keen eye..
  #163
Old 05-11-2016, 08:02 PM
grandville455's Avatar
Your welcome!! It worked in the grandville when u did my T2, I think ernie will like it
Darby
M/T 275/60 ET SS Drag Radial
  #164
Old 05-11-2016, 11:59 PM
Will Will is offline
A question for you guys running T-2s - how much taller than stock are they?
Thanks!
  #165
Old 05-12-2016, 12:25 AM
Thanks!
The Torker II is .400" taller than stock, straight out of the Edelbrock catalog.
  #166
Old 05-12-2016, 01:21 AM
Thanks b-man!
  #167
Old 05-13-2016, 10:55 AM
That was a lifetime ago, Ernie's intake is one of my best port jobs so far!
What is the Engine Combo in the Grandville now?
I'm building up my 72 4dr Catalina, 4550lb Race Weight LOL
I want to know more about your setup! You can PM me so i don't derail this thread. Thanks
Derek Stewart Racing Engines
  #168
Old 05-13-2016, 11:32 AM
Out testing...off idle
  #169
Old 05-13-2016, 01:27 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Nice stripes there, TAman! Great thread, love the change/test/updates.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #170
Old 05-13-2016, 01:30 PM
tpssonic's Avatar
tpssonic tpssonic is offline
X1000
  #171
Old 05-13-2016, 05:22 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Looks like you lost a lot of low end with that single plane, yea right!
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #172
Old 05-13-2016, 06:21 PM
Yeah...runs good..the Wilson tapered spacer helped a Cpl years ago made it much snappier....
  #173
Old 05-13-2016, 06:51 PM
I know right, even worse its ported :-( He will barely get out of his own way with a ported single plane LOL
  #174
Old 05-13-2016, 09:50 PM
71 T/A 71 T/A is offline
A Pontiac owner's best friend - a long deserted road.
  #175
Old 05-19-2016, 11:26 AM
77 TRASHCAN's Avatar
Originally Posted by Torquewar View Post
The 20th will be fun with TA man and CNC. The trio of second gens will make there presence known.
Darn weather better co-operate...
How's the weather looking for tomorrow? Gonna have to mount your mud grips?
Shut it off
Shut it off
  #176
Old 05-19-2016, 02:43 PM
Weather looks good..Sunny and 70 degrees in the afternoon..won't need my snow tires,also swapping the skis on the front for my skinny Welds/Mickey SR's....just need to shovel the car out from the snow bank and I'm good to go!
  #177
Old 05-20-2016, 10:47 AM
Awesome, good luck Dude!
  #178
Old 05-21-2016, 02:13 AM
Well we all had a good night at the track....everybody that was with us ran quicker, a Cpl fresh builds with no issues.As always traction was the key at this track.....my first run was my new best...11.30.18 at 120.58 with a 1.6509 60ft...next 2 runs were traction impaired but both over 120mph....my last run of the night..sorta surprised me...we thought the track was getting slippery..after a big burnout..ran 11.3223 at 121.35 with a 1.6798 60 ft with a slight spin.The car is definitely making more overall power..only once before has it ran in the 120's and that was wind aided.The only part that was changed from last year was the intake..jetting and timing remained the same...I did change the front squirter on the carb after first run...the car may pick up slightly with perfect traction..Big thanks to Pontiac Derek for the porting of this intake..it increased topend power but also kept the big fat torque curve.
  #179
Old 05-21-2016, 09:11 AM
goathead455 goathead455 is offline
What rack were you running at ?
  #180
Old 05-21-2016, 09:15 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job! Sounds like fun.
Go fast, see Elvis!
