Old 05-24-2016, 08:24 AM
original driveshaft has been replaced.
  #42
Old 05-24-2016, 08:44 AM
The Boss's Avatar
The Boss The Boss is offline
Think that's original? Check Dan's T-37 for comparison...
Not.
And go racin' in the street.
  #43
Old 05-24-2016, 01:14 PM
SD455DJ SD455DJ is offline
We didn't think so either. 2-piece driveshafts with the rubber slip joint looks very lo-po and generic (non-factory) to us, from another A-body division. So, time to Get a new one made.
Dennis
  #44
Old 05-24-2016, 03:07 PM
The Boss's Avatar
I may have an extra Dennis, can check for you.
  #45
Old 05-24-2016, 03:22 PM
carguy66cars's Avatar
carguy66cars carguy66cars is offline
Looks like another great project Dennis, with most of the hard to find stuff there! So any idea if '70 Grand Prix 455 car driveshaft would be the same? If Chris can't come up with one I should still have the GP one! Sold the rear to another member years back, but still have that driveshaft somewhere?
Lyn.
'72 400 M22 4-speed Lemans Sport GT
'72 400 4-speed Luxury Lemans
'72 Luxury Lemans 4dr. hardtop 45,000 mile car
'72 Lemans 2dr. 20,000 mile car [sold]
'73 Grandville backhalfed Drag Car
'73 Grand Am 400 4-speed
'74 Lemans Sport Coupe-4800 original miles
  #46
Old 05-24-2016, 03:27 PM
Chris & Lyn, Thanks for the offers. I'll let both of you know, but I have to check both Dan's and my stashes first. I jumped the gun by saying I need a new one made...in reality, we may have an A-body shaft lying around as well.
Lyn, the GP has a 118" wheelbase vs, the 112" for the A-body, so the GP driveshaft is longer. Thanks anyways!
Dennis
  #47
Old 05-24-2016, 05:22 PM
The GP driveshaft is the same, right down to color bands.GP engine sets way back. The rubber isolated driveshafts, first ever ran across them were short ones out of '69 Birds. For some reason Olds started using them a lot around '71-72. Have pulled them out of quite a few Cutlass I was parting. My bet, the rubber isolated driveshaft you have Dennis has to have come out of a longer wheelbase Abody, then was shortened on one end
  #48
Old 05-24-2016, 05:45 PM
Roger, Thanks for the schooling on the GP driveshaft length being the same as the A-body. I forgot about the engine setback with the deeeep fan extension on the radiator shroud.
Dan recently bought a true survivor 1970 F-85 Olds with 39k miles and 100% original. It is a factory 310 hp 350/TH350/3.23 high altitude gear car. It is totally rust free high dessert car (SW Colorado). The paint is tired but the interior is mint (Olds version of Bermuda blue with optional blue vinyl guts), the point is it has the same rubber isolated driveshaft and has the correct stripe code colors for Olds. Soooo, I'm thinking it may have come from another F85/Cutlass. I wonder if Buick Skylarks had the same shaft....?
Dennis
ID:	429135   Click image for larger version
ID:	429136   Click image for larger version
ID:	429137   Click image for larger version
ID:	429138   Click image for larger version
  #49
Old 05-24-2016, 05:55 PM
Wouldn't the manual trans (especially with a 455 HO/M-22) car been equipped with the rear fram reinforcements like on the GTO's?
Dennis
Name:	Reinforce Bars 004.jpg
ID:	429142   Click image for larger version
Name:	Reinforce Bars 005.jpg
  #50
Old 05-25-2016, 07:24 AM
BTW, the pictures in my previous post are of the Ames repops we installed on my 70 Lemans. There aren't any on the GT-37 right now and not sure there ever were.
Name:	McKinnon 12-Bolt.jpg
ID:	429207   Click image for larger version
ID:	429208   Click image for larger version
  #51
Old 05-25-2016, 07:32 AM
Also appears the M-13 may not be the original trans. No date VIN on the pad and the casting dates are B, D, & E of '70 which is probably too early.
Any thoughts?
Dennis
ID:	429210   Click image for larger version
Name:	M-13 Side Cover.jpg
ID:	429211   Click image for larger version
Name:	M-13 Tail Housing.jpg
  #52
Old 05-25-2016, 07:34 AM
Here is another '71 M-13 for comparison...
Dennis
Name:	71 GTO M13 007_resized.jpg
ID:	429213   Click image for larger version
Name:	71 GTO M13 010_1_resized.jpg
ID:	429214   Click image for larger version
Name:	71 GTO M13 012_resized.jpg
ID:	429215   Click image for larger version
Name:	71 GTO M13 013_resized.jpg
ID:	429216   Click image for larger version
Name:	71 GTO M13 006_resized.jpg
  #53
Old 05-25-2016, 07:49 AM
The Boss's Avatar
I could check the M13 from mine - see what the date range is on it.
  #54
Old 05-25-2016, 07:55 AM
Judge273's Avatar
Judge273 Judge273 is offline
As far as VIN stamped on transmission. My old Fremont built M-22 didn't have that stamped?
Mike/Illinois
  #55
Old 05-25-2016, 08:17 AM
Chris, That would be interesting to know. It very well may be since the were infrequently installed/ordered, that there was extra '70 casting M-13's to use up. Strage that it doesn't have a VIN or the stamping below the side cover.
Here is another from a '73. VIN: 23A157783
Dennis
ID:	429218   Click image for larger version
ID:	429219   Click image for larger version
ID:	429220   Click image for larger version
ID:	429221   Click image for larger version
  #56
Old 05-25-2016, 08:22 AM
The case stamped number is H3A02B, Correction VIN is 23A157788
Dennis
  #57
Old 05-25-2016, 03:20 PM
The Boss's Avatar
Texted pics to Dan - no VIN on my trans either.
  #58
Old 05-27-2016, 09:00 AM
455HOGT37's Avatar
455HOGT37 455HOGT37 is offline
Nice to see my old car getting some attention again. Was not doing anyone any good stashed in the corner of my shop.
I'll do my best to shed some light on any mysteries uncovered in this thread, but I owned that car for a LONG time and had a lot of engines in and out of it. I can tell you the trans was the one in the car when I bought it in 88, and I always wondered about the missing VIN. I find it unlikely that the original owner blew up the M-13 and then replaced it with another. Possible, but does not add up to me. And as far as I know, thats the driveshaft that was in the car from 88 as well. I did a lot of cross breeding of parts among my fleet back when I was a kid, but that was my only car with the Chevy rear end yoke, so I think it was always in that one.
I'll be following this thread with interest.
  #59
Old 05-27-2016, 09:38 AM
Judge273's Avatar
That car was my inspiration car...
I think I even PMed Mike about buying it....if I remember it wasn't for sale.
Of course it was after I finished the one I did buy.
Now maybe my car is the inspiration?
Mike/Illinois
  #60
Old 05-27-2016, 10:51 AM
Mike (455HOGT37), Welcome to the party! Any an all back story and input will be very welcome. I'm sure any stories you have about the cars street life when you were driving it will be 'must reads'. Fortunately, I have a few 71 455HO A-bodies nearby to compare with.
Mike (Judge273), Yep, your car is the flipped inspiration, but I can't take it to that level perfection dollar-wise. My goal is to make everything work, replace any missing pieces, including the a/c, clean the interior (I'll probably install a nicer cash pad and formula wheel with original less cracked & sun baked replacements. I might even remove the existing hand-made eyebrow stripes with troops and somehow patina them the match the paint (spray on a flat clear?). Anyway, those are the ideas Can and I have been discussing. They could change the further we get into it.
Dennis
