Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
![]() Quote:
My Half AN Injun..... |
![]() Quote:
At the track last night I only went to watch an Outlaw race, but my buddie is friends with the track owner. He let me make two passes to test. At first I was all disappointed with what it ran. I thought " wtf?" It didn't feel right, and I was nervous with not being on the track in four years and having a lot of people there watching. I just made my passes and left. On the road home I rolled into a couple of times and looked at the boost gauge because I was thinking about it not being as strong as it was. Only 6psi! Damnit. I used push to lock line on my reference lines and the wastegate line pushed out lowering my boost. Those lines will not be on there next time. This picture is what the intake looked like before. |
Charlie, seeing you run EFI now, you may want to consider building a new intake. Plenty of places on the internet for info/ideas. Suggest YellowBullet. A modified tunnel ram could make a good starting point.
At your 4 cylinders @200 ci you'll want approximately a 300 ci plenum. Thats a box 15"x4"x5" (inner dimension)or a 15"x 5" ID tube. (total plenum = space between throttle plates and ends of runner. You could use other dimensions to come up with a 300 cfm plenum btw.) Pypemax should give you an idea of how long you want your runners. |
![]() Quote:
My situation is complicated by the shape of my blower outlet. The high-helix blower has a small teardrop-shaped outlet at the front of the blower on the bottom. That limits air distribution. I'm running .036" & .038" port injectors in the front, tapering down to .032" on both sides in the back. That keeps the EGT's close on all cylinders, but implies the front half of the engine makes more power than the back half. I've wondered what effect that might have in the long run, if any. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
![]() Quote:
![]() For a 4 cylinder engine, it would take a lot bigger plenum than what a V8 would use. ![]()
Why would a 4 cylinder need a larger plenum than a v8? Just asking?
![]() Quote:
![]() Quote:
![]() Quote:
That sux about your boost being low but it still ran good. Just imagine what it will do at 12 and a tight converter1 I bet some low 9's! I had some fun this morning. My girl and I went to this big car show and on the way home wound up being in the middle of a pack of new vets. As they were all passing me I cut in the middle of them , the one in front of the pack downshifted 3 times at 50 mph (guess he had a paddle shifter) He was about 200 feet in front of me when he hit it. I drove right to him like it was nothing. At about 20 feet off his bumper I lifted . As all the others drove bye they all gave me the thumbs up. lol.. I know that guy thought he was going to smoke me. Would of loved to tell him I only had a 4 cylinder.....
What would your suggestion in size be?
Give me some engine specs:
Bore, stroke, rod length, intake diameter,cam duration, LSA, and I can run PipeMax on it. ![]()
![]() Quote:
4.090 bore 6.635 Rod length 2.15 intake valve 251 242 .050 114 lob separation
Max rpm will be only 6500.Will be running high boost levels. Wouldn't be afraid of 50 psi just incase of that being a factor.. hahaha! seriously .....
Stroke?
(3.75"? 4.25"?) Also what is the head flow? ![]()
That's what I figured.
Looks like PipeMax doesn't actually give a plenum volume. (it would be for a N/A application also) It gives the usual min as the single cylinder size to the max of the total engine CID. A calculator I have says for your engine it would be around 156 cubic inches. But a lot of 4 cylinder racers have been using up to 2 times the CID of the engine to get the HP out. (446 in your case?) Plenum volume is not really understood as well as it could be. Also the carb/Throttle Body needs to be bigger than a V8 type size. (for the same reasons basically as the plenum) PipeMax runner data (in inches): - Induction System Tuned Lengths - ( Cylinder Head Port + Manifold Runner ) 1st Harmonic= 33.676 (usually this Length is never used) 2nd Harmonic= 19.114 (some Sprint Engines and Factory OEM's w/Injectors) 3rd Harmonic= 13.344 (ProStock or Comp SheetMetal Intake • best overall HP ) 4th Harmonic= 10.503 (Single-plane Intakes , less Peak Torque • good HP ) 5th Harmonic= 8.521 (Torque is reduced, even though Tuned Length) ![]()
![]() Quote:
#38
Build your plenum so you can easily add more. I stated 1.5 x engine displacement...I'd start there.as a minimum. Test and add space and see what it does for you. Pypemax runner length factors the distance from valve center to manifold face.
#39
A 156 cubic inch plenum volume works out to around a 80% vs displacement plenum which would be correct with a good flowing NA Intake manifold.
I always thought that a Wenzler Tunnel Ram intake manifold with half of the runners cut off at the base of the plenum and 4 runner plugs welded in even with the plenum floor would make an "easy to create and fairly cheap" large volume Boosted 4 cylinder intake manifold. You could also feed the plenum in the center and get better runner distribution vs feeding from a end position BUT with the right lid design and a "End Feed" with a throttle body deal would work well too. Tom V.
#40
![]() Quote:
