Old 06-12-2016, 09:35 PM
Pepi's Avatar
Pepi Pepi is offline
Wow, lucky (and unlucky) you. Glad you were able to fish it out!!
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #562
Old 06-12-2016, 09:53 PM
Formulabruce's Avatar
I believe I have one from my '73 L75 I will look on Monday .
" Long may we DRIVE !"
  #563
Old 06-13-2016, 06:34 AM
The Boss's Avatar
The Boss The Boss is offline
Unless those are two different dip sticks Steve, I'd say you still have a piece in there. Those don't match up to a single break - you're missing the other side of the hole.
And go racin' in the street.
  #564
Old 06-13-2016, 06:59 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
I believe Steve stated he had filed/smoothed out one end of his dip stick hoping it would aid in getting the broken piece out. In the pic, the rounded out dip stick and broken piece are the one from the 73. The dip stick shown below it is from his Grandmothers 75.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
  #565
Old 06-13-2016, 07:00 AM
njsteve's Avatar
njsteve njsteve is offline
It is the matching part. I filed the end of the dipstick smooth to use it as a probe. That's why they don't match now. It was too sharp to use initially and was just jamming in the tube when I first tried to use it to see where the missing piece was.
  #566
Old 06-13-2016, 07:10 AM
The Boss's Avatar
Ok, missed that part.
Just wanted to be sure you're not missing that part!
  #567
Old 06-13-2016, 07:20 AM
njsteve's Avatar
I always laugh when people use that old saying: "Why is someting always in the last place you look?" Well, that's because you stop looking after you find it. I am a firm believer in continuing the search even after you found it.
...just in case there was another broken dipstick end down there somewhere.
You'll be happy know there was nothing. An as an added bonus the magnet was completely clean - no metallic residue of any sort was on the magnet when I wiped it off.
  #568
Old 06-13-2016, 12:06 PM
njsteve's Avatar
That would be great!
  #569
Old 06-13-2016, 10:12 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
What about welding it back & re drilling the hole?
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #570
Old 06-14-2016, 01:04 AM
cal30_sniper's Avatar
cal30_sniper cal30_sniper is offline
Here's a couple of pictures of the original dipstick out of my '73 L30 engine. Looks like exactly the same dipstick. I think I'm going to learn from your troubles and install the spare '74 400 dipstick along with the new short block.
'73 Formula - Buccaneer Red Matching #s, Resto in progress, 350 Pontiac (For now)/Doug Nash 4+1
'86 C20 Suburban - 454/NV4500
  #571
Old 06-14-2016, 07:12 AM
njsteve's Avatar
Yup, that's the same dipstick. Why didn't they just stamp on it: "Break here and insert into oil pan"
Ugh!
  #572
Old 06-14-2016, 07:13 AM
njsteve's Avatar
I wouldn't trust it since the weld would be harder than the surrounding metal, causing the dipstick to break at a new point above or below the weld.
  #573
Old 06-14-2016, 08:32 PM
Its 31.25 overall total length.( A/C dipstick) . I have one from the L75 right here, handle needs some evporust.
price is right, but I need to find a long enough tube..
ID:	430795   Click image for larger version
  #574
Old 06-14-2016, 08:36 PM
Mezzo's Avatar
Mezzo Mezzo is offline
So apparently the 1973 L75 took 5 quarts of oil versus the 1972 455 HO took 6 quarts of oil.
  #575
Old 06-14-2016, 08:57 PM
I think they both take 6 , but yes this stick is from a '73 L75
  #576
Old 06-14-2016, 09:31 PM
njsteve's Avatar
Thanks Bruce! A couple of foot section of PVC plumbing pipe works great for shipping. I can PayPal you some cash for materials and shipping, etc. PM me your PayPal info. Thanks again for the help.
  #577
Old 06-14-2016, 10:19 PM
4birds's Avatar
4birds 4birds is offline
I've been down this road a few times. All have been A/C dipsticks. Welding them doesn't work either. Fortunately, I have never broke a non A/C dipstick....yet!
  #578
Old 06-15-2016, 04:25 PM
frank.g frank.g is offline
Hey Steve, if I were you, I would keep the replacement 73 dip stick as a prop, and use the non-73 dip stick for day to day duty. I do that with the fuzzy air inlet hose and the radiator cap (I run the car with a 7 lb cap to maintain lower pressures on 43 year old radiator and heater core). Standard show-prep duty has me swap out the operating parts for the original "props".
Another solution is to keep your original dip stick in the engine, and keep a non 73 with you. When you want to check the oil, remove 73 and use the other.
  #579
Old 06-15-2016, 08:52 PM
njsteve's Avatar
I'll use the new one as a show piece and the broken one as the "driver" dipstick. The one I used for comparison in the photos was from Gramma's car so I can't steal that one without facing the Wrath Of Gramma.
  #580
Old 06-15-2016, 09:22 PM
blue71ta's Avatar
blue71ta blue71ta is offline
5 quarts in the pan + 1 in the filter = 6 total
