Old 06-22-2016, 04:17 PM
Faustmill Faustmill is offline
Default Is there an overdrive for 4 speed trans?
67 GTO with Muncie 4 speed and 3:55 rear.
I am turning 4000 rpm at 70 mph and 3500 rpm at 65 mph. These rpms are just too high for me on longer highway cruises. I think the car would be lot more comfortable at, say, 2500 rpm at 70 mph. Is there any transmission bolt-on gear box that would give me a high/low range and still allow me to keep the stock Muncie 4 speed? Thanks.
Old 06-22-2016, 04:23 PM
richardk's Avatar
richardk richardk is offline
http://www.gearvendors.com/
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
Old 06-22-2016, 06:18 PM
android 211 android 211 is offline
Autogear sells a 'M-22Z' Rockcrusher which is a M-22 with a lower low gear set. 1st is available with 2.97:1 I believe. You swap that in for your M-21 and exchange your 3.55s for a cheap 2.73 rear axle assembly and you get the same off the line launch and lower highway rpm. No new driveshaft or cutting the floor. There will be more drop in rpm between shifts. $2200 before shipping.
Old 06-22-2016, 06:54 PM
tom s tom s is online now
There was a gear set made in Italy for muncies with a .85 4th gear.Only rub was a 2.20 first avail in it.I had one in my 69 bird with a 366 RAV short deck engine.Was very good in it with a 3.90 in the back.Dont think it would be great in a GTO weight car unless it had some cubes like a 455.Tom
Old 06-22-2016, 07:14 PM
I'ld like to have one of these.
http://www.richmondgear.com/index.ph...t-5-speed-w-od
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 06-22-2016, 08:16 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
If you are turning 3500 rpm at 65 mph you should be running 74 mph at 4000 unless you have a bunch of clutch slip. Just curious, what is the diameter of your rear tires?
Old 06-22-2016, 08:32 PM
Yes, I agree, something ain't right there.
With a 27" tire, I come up with 79mph at 3,500rpm
27" tire, 4.10 gear, 3,500rpm would put you right at 68mph
Poncho & Lefty
Old 06-22-2016, 09:42 PM
KJL's Avatar
KJL KJL is offline
Have one in my 70 GTO with 3.90 gears and it works great. Just have to get used to the ratio changes. Second to forth is steep an third to forth is shallow. Had a m22 with 3.55 gears and a 71 400 (low compression) and it was not a problem with the 2.2 first gear. If you have a cammed 400 it may be a different story.
Old 06-22-2016, 09:59 PM
I knew someone would raise this issue. The rear tires are 26.1". So with a 3:55 rear, the calculator says 70 mph would be 3200 rpm (not 4000 that I am turning). These are rebuilt factory gauges (tach and speedometer), not aftermarket. The clutch does not feel like it is slipping. So I do not know how to explain this but you raise a good point. All I can say is that I have driven the car for 11,000 miles over the last 8 years and the tach says 4000 when the speedo says 70. Thanks to everyone for the thoughtful comments and suggestions.
Old 06-22-2016, 10:05 PM
If you have a smart phone,put in the wake app.Shows actual speed in MPH,no guessing.Tom
Old 06-22-2016, 10:23 PM
Before you worry about changing things I think you should get an accurate base line. Either your speedometer, your tach or both are incorrect.
Beg, borrow or steal a GPS unit. Set it to display MPH and take it out on a highway without a lot of traffic. Run the car at 60 MPH as displayed on the GPS and record what the speedometer says. Do the same at 70 as indicated on the GPS and a few other points, say 40 and 50.
Old 06-23-2016, 10:38 AM
goa484's Avatar
goa484 goa484 is offline
Tom,
What company makes that app? I searched for it and couldnt find it.
Brad
Old 06-23-2016, 12:47 PM
Originally Posted by goa484 View Post
Tom,
Brad
Here's some...
https://play.google.com/store/apps/d...es.speedometer
https://itunes.apple.com/us/app/spee...286577228?mt=8
Poncho & Lefty
Old 06-23-2016, 01:02 PM
Don 79 TA Don 79 TA is offline
why not swap in a TKO box
not sure how much floor massaging is needed for your app, check with that first
Old 06-23-2016, 01:17 PM
I have a M22Z, but would disagree on the 2.73's. I have 2.93's and were I to do ti again would run 3.08's. This with a KRE headed 440.
Old 06-23-2016, 02:21 PM
There was also a company that made an OD for the Nash/Richmond 5 speeds instead of 5th being 1:1.
Old 06-23-2016, 02:56 PM
frbformula's Avatar
frbformula frbformula is offline
Im planning on running a M23z muncie from midwest muncie. That coupled with a 3.00 rear gear (Ford 9in) will put 1st, 2nd, 3rd final ratios very close to my current Th400 with 3.73 gears. Then the 1:1 4th gear in the trans will act as some what as an over drive. For me that is the best compromise for me. I want the feel of an original 4 speed but with a decent highway gear.
Old 06-25-2016, 08:44 AM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Originally Posted by richardk View Post
Very interesting reading. My only issue is my current setup is the worst of all worlds. M21 with 3.42 ain't great for routine launches or low speed cruising. And while 3.42 isn't horrible I the highway, I'm not comfortable cruising over 3,000 for extended periods, meaning I'm staying below 65mph with 26" tires. Some day maybe I'll change everything. Lol
So thanks for this info. Good reading
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
Old 06-25-2016, 09:48 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Dropped my m20 for a tko 5 speed last year after a 4 hr round trip to Woodward at 3000+rpm.
Easy install ( in a FB anyway) and flawless. Prpbs $3600 total w hydraulic clutch and twin disc upgrades. Just keep in mind I don't race so unsure in a street strip application. I have heard both good and bad on longevity if racing.
Steve
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 06-25-2016, 10:16 AM
AdamIsAdam's Avatar
Steve
I would think that would be the better way to go for a set up like mine as long as that tranny can survive being behind 550+ foot-pounds of torque. 99+ percent street use but I do have a heavy foot. But I've heard it's a rough install.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
