Old 06-19-2016, 07:48 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Talking front shock choice for 67 FB
I am currently using Moroso front coils with Koni shocks in the Firebird. I was looking at changing to a QA1, or Santuff coil over arrangement. The goal is to try and keep the front end down, going down track. Too much air is under the car with the moroso,koni deal. What set up are you guys using. Time to get rid of the old school set up.
Old 06-19-2016, 03:03 PM
Ron H's Avatar
Ron H Ron H is offline
Front spoiler or airdamn under the front bumper.
No matter what shock spring set up the car will lift to the top of the shock stroke. So shortening the rise height helps.
I use qa1 double adjustable coil overs. They have decent height adjustment. They are a mid level shock. Do the calcs so you get the right spring rate for your car.
68 Firebird
Are you running with the wind or breaking it?
Old 06-23-2016, 01:41 PM
Curious George's Avatar
Curious George Curious George is offline
I'm running Viking Crusaders, so far so good.
https://www.youtube.com/watch?v=sj_0peOGAdo
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 06-27-2016, 08:26 AM
I,m leaning towards Strange Double adjustable shocks. They seem to have good settings on both extension and rebound.
Old 06-27-2016, 01:30 PM
janderson's Avatar
janderson janderson is offline
Let me know what you come up with Mike, I need to make a change on the '68.
