67 and 68 speedo/gauge cluster differences...
Are there any differences in between these 2 years?
Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
No, I do no think so. both year had the same speedo options: std, SafeGuard, auxiliary gauges, and very rare aux gauges w/ SafeGuard. Both years used the slate blue grey back ground color. The wiring is interchangeable.
In '69 things changed. The speedo units went to a printed circuit board as opposed to individual wiring for each bulb or gauge used previously. '69 and '70 units are interchangeable except that '69 used the slate blue grey background color. In '70 they changed to a charcoal black color.
'69 Bonneville convertible Warwick blue/ parchment interior 53 option accessories 2 more to go :-) |
gauges
I have what I believe is a 69 rally gauge set in good shape if anyone needs one.
'67 & '68 clusters are the same. |
yes, on the gauges versions there is a low fuel indicator light (red) on the fuel gauge. They should have put that on all of them. Almost forgot in '69/'70 there is another speedo unit version that has seatbelt warning light
How about a picture. PM me. thanks.
My non-rally gauge cluster in my '67 wagon had a low fuel light. Timewarp has the car now, so I can't take a picture.
Jim K in PA 1967 GP HT 428 1967 GP convert 428 1957 Chieftain 4D HT |
I did not know that. I wonder if all 67's had the low fuel indicator light and if that gauge could be swapped into a later model ('69 or '70 - color would be wrong) that did not have the low fuel warning light. Hmmm.....
The fuel warning light is activated by a little round cylinder that mounts directly onto the back of the fuel gauge posts, so theoretically you could transfer it from one car to another. Maybe even get one from another model car like a Buick or Cadillac. Getting the light installed correctly would be the tricky part. The '67-68 full size clusters had a rectangular light hole and lens for it, perhaps a simple drilled hole in the actual fuel gauge where the LED\bulb could be mounted...
Attached a couple of pics with Low Fuel on Standard and Rally Clusters
------------------------------------------------------------ 1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles 1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles 1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles 1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles |
