Old 09-28-2016, 12:31 AM
ta man ta man is offline
The dragstrip we go to will run until late October just depends on weather ..I'm planning on at least another weekend...I know Andy was talking about this weekend coming up...
  #502
Old 09-28-2016, 12:37 AM
Will Will is offline
What do y'all think a 433 with the SD 295 KRE's, an OF with 1.65s backed up by a Coan 3200 converter and 3.23 gears would be capable of? Not quite the cubes you guys have...
  #503
Old 09-28-2016, 07:13 PM
cnc's Avatar
cnc cnc is offline
So, will you all get another shot at the track before the weather turns?
Certainly hope so
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #504
Old 09-28-2016, 08:51 PM
Torquewar's Avatar
Torquewar Torquewar is offline
[QUOTE=Will;What do y'all think a 433 with the SD 295 KRE's, an OF with 1.65s backed up by a Coan 3200 converter and 3.23 gears would be capable of? Not quite the cubes you guys have.
Like it, . Couple things ....what carb intake combo.
Fuel system supply.
Exhaust system.
What kind of vehicle, weight is a big consideration. 3:23 gear will work but a lighter weight will help.
Strip times ..all depend on the above and of course vehicle set-up.
  #505
Old 09-28-2016, 11:56 PM
Intake would be either fully ported stock or a Holley SD. Might be able to squeeze a 1/2" spacer in there but that's pushing it. 800 Cliff prepped Q-jet.
Not sure which headers - either Hooker Super Comps or Tribal Tube Tri-Ys to 3" pipes with X to 2.5" cone reducers just before pipes go over the axle to a Pypes crossflow setup. I'll probably go with the Tri-Ys for clearance reasons.
Fuel system will be whatever it takes to keep it fed. As long as fuel pressure stays steady at 4-6 psi at carb inlet during the run, it doesn't really matter, does it? I'll probably end up going with one of those in-tank pumps in the spiffy baffled tank. Can't remember who makes 'em right at the moment... Tanks Inc.?
'72 Formula - 3800+ lbs fully loaded with AC and a kickin' stereo.
  #506
Old 10-04-2016, 12:26 PM
Best timeslip from last outing..the reaction time is huge we were running off an instant green!Andy should post his 10.99 if he has a camera quick enough to catch it!
  #507
Old 10-04-2016, 01:23 PM
grandville455's Avatar
Awesome MAN!!! Congrats
Darby
M/T 275/60 ET SS Drag Radial
  #508
Old 10-10-2016, 07:50 PM
cnc's Avatar
cnc cnc is offline
Well....Finally did it
  #509
Old 10-10-2016, 07:56 PM
grivera's Avatar
grivera grivera is offline
Nice job getting well into the 12s!! Congrats!
Will Rivera
  #510
Old 10-10-2016, 08:07 PM
johnta1 johnta1 is online now
Congrats on the 12 second pass!
  #511
Old 10-10-2016, 08:17 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Good job!
Go fast, see Elvis!
  #512
Old 10-10-2016, 08:25 PM
Torquewar's Avatar
The Pontiac Trio was missing our buddy TA man....
  #513
Old 10-10-2016, 08:58 PM
form74's Avatar
form74 form74 is offline
Chris, Very nice 12.73
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
  #514
Old 10-10-2016, 09:25 PM
cnc's Avatar
cnc cnc is offline
Fixed it was upside down for some reason...lol
Next time out Drag radials .....hopin to get the 60 foot down ......
Thanks guys had a great time ...Missed u today Ernie.....
  #515
Old 10-10-2016, 09:39 PM
Missed coming...had a nice family weekend over the holidays...Congrads on the 12 second slip
  #516
Old 10-10-2016, 09:57 PM
David Jones's Avatar
Cool.
  #517
Old 10-15-2016, 10:27 PM
New best again!Only thing changed from last time was upping the rear squirter on my Holley from a 31 to a 35....3 best runs Friday nite in nice cool air...11.240/122.59 1.6710 60 ft..bit of a hesitation on the line...2nd run 11.1321 at 123.33 with a 1.6840 60 ft..still with a hesitation..next run I decide to launch up at 2500 rpm...best 60 ft ever...1.6080....it felt like a good run......11.03 at 123.60mph!I never thought it run this quick!I made a few runs this afternoon..fought marginal traction and a strong headwind..et's ranged from 11.20's to 11.70's smoking the tires..mph was 121 into the wind...
I may make it out again this year..but if not ..I'm really satisified with the et drop...went from a best of 11.3893 at 120.63 to 11.03 at 123.6 just with Pontiac Derek's port work on a new Torker 2..and dropping the tailpipes...some of the easiest et gains for the dollar I have done yet.
  #518
Old 10-15-2016, 10:30 PM
wheelspin's Avatar
Thumbs up New 12 second club member...
Nicely done, Chris!
Les Iden
  #519
Old 10-15-2016, 10:46 PM
New best timeslip...may be hard to beat until next year..good traction,cool air and no driver error!
Name:	new fastest timeslip.jpg
  #520
Old 10-15-2016, 11:02 PM
11.0359 @ 123.60.
Incredible, 11.0s at nearly 124 MPH with a 3.08 gear set.
Street hero.
