Old 10-16-2016, 10:15 PM
Vince GTO's Avatar
Vince GTO Vince GTO is offline
Default TH400 with transbrake problem
Anybody ever have any issues with a Coan transbrake rolling forward when applied? It has been in the car for four years with no issues but last night in the third round once I pressed the transbrake button it rolled forward? I unloaded the car tonight and it does it every time now! Going to call my trans guy tomorrow just interested if somebody has seen the problem before.
Thanks Vince
Old 10-16-2016, 11:07 PM
Old Man Taylor's Avatar
When I had that problem with mine it was due to the ground connection for the TB solenoid deteriorating. I improved the grounding, and no more problems.
Old 10-16-2016, 11:11 PM
Vince GTO's Avatar
Thanks for the advice I will check that tomorrow!
Old 10-17-2016, 06:58 AM
There can be a couple of other things.
The band adjustment can be off a little bit.
The pump pressure can be too low.
Old 10-17-2016, 10:53 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Coan could definitely point you in the right direction.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 10-18-2016, 12:43 PM
WARPed's Avatar
WARPed WARPed is offline
ditto, move your ground wire to one of the bell housing to block bolts if you have it on any trans case bolts.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 10-18-2016, 06:35 PM
cgeise's Avatar
cgeise cgeise is offline
if memory serves there is no bad adj on a th400 -- is the valve body one that needs the t/b button pushed to engage reverse ???
Old 10-18-2016, 08:28 PM
Vince GTO's Avatar
No the button does not need to be engaged for reverse.
Changed the ground installed a new wire right to the back of the head where the main ground is connected no change.
I talked to Coan today they had a few suggestions but the main issue seems to be low line pressure. I measured it tonight at 170psi. Coan suggested raising the rpm before engaging the brake that did not help my situation pressure stayed at 170psi. They also asked what my staging routine was and suggest after going to neutral to clean out the engine to press the transbrake button a few times to ensure the pressure has built up after going into neutral and before I pre-stage also no help for me. Thinking the pump needs rebuild?
Old 10-19-2016, 10:49 AM
The pump is where I would start. I'm not familiar with Coan brakes but I'm assuming they supply you with a stiffer pump spring? Check that as well.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 10-19-2016, 05:17 PM
Probird's Avatar
Probird Probird is offline
Possibly the reverse clutch pack is worn and has too much clearance.
I don't know about a th400 but when the pump is weak in a glide it rocks backwards.
Sounds like a pump pressure problem though. If there isn't enough pull out of the converter from the transmission when you bolt it to the flexplate it will eventually eat out the back half of the pump and cause a pressure drop.
I'm assuming it just rolls a little bit forward? Or is the transbrake just not holding at all?
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 10-19-2016, 08:55 PM
t400 reverse works when direct clutches are applied AND low/reverse band is applied. If a direct clutch problem 3rd gear could be at fault.
An issue with the reverse band,the pins that hold it or its servo perhaps?
Worn clutches/seals or cracks in drum(s) or case can bleed pressure as can servo issues.
Old 10-19-2016, 09:26 PM
Vince GTO's Avatar
Yes, it moves forward about an inch.
Old 10-20-2016, 07:20 AM
taff2's Avatar
taff2 taff2 is offline
After 4 years of use it's probably time it was looked at anyway,just as a maintenance item. It's better to catch the fault before it does any real damage. Pull the oilpan to see how much clutch material etc is in the bottom,if it's clean,try a new solenoid first.
Old 10-20-2016, 09:27 PM
Vince GTO's Avatar
That's what I did tonight except the new solenoid(took it apart and cleaned it). No change fluid looked good a little metal on the magnetic plug but figure after two seasons on the fluid I would think that is normal. I may just footbrake it the rest of the year it's only two more races what the heck!
Old 10-25-2016, 11:35 PM
Torment's Avatar
Torment Torment is offline
Make sure the spool valve under the solenoid is moving freely - they can chew into the case over time.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 10-26-2016, 06:11 PM
cgeise's Avatar
The th400 is slower to engage the t/brake than a P/G -- if your routine is to get off the foot brake to fast then it may roll forward just a tad - I experienced this when going from my p/g supergas car to my th400 turbo car -- the fix was to wire the line lock to the delay box so the front brakes stay engaged when the t/b button is depressed, it releases apon release of the t/brake - that car went from rocking back and forth to dead solid
Old 10-26-2016, 09:24 PM
Vince GTO's Avatar
Sounds like a good idea but I have a question? You would not be able to use the line lock in the burn out box without engaging the trans brake if wired together. Did you add multiple switches or use a diode to isolate the line lock?
Old 10-26-2016, 10:36 PM
Vince (take delay box out of picture)if you have 2 switches...
power in to line lock switch 1st...turn on line lock... power out of line lock wire also wired to transbrake power in side of transbrake switch...
the trans brake wont turn on until its switch is turned on.
When you turn off line lock switch you simultaneously drop power to both line lock and transbrake switch.
Old 10-27-2016, 01:13 PM
cgeise's Avatar
when used thru a delay box-- mine is, Dedenbear - it is diode protected and only goes one way
