64 and 65 doors.
I did several searches but can't find the answer. Are 64 and 65 doors interchangeable? I have an interchange book that says they are but not sure.
If your talking about 64-65 LeMans - GTO doors. The answer is yes. As long as you match post doors to post doors and hardtop to hardtop.
Thank you.
They will interchange , but there is differences .
I believe the difference is the lock cylinder clip. 65's are internal while 64 doors have a slot in the door jamb for a longer clip.
Thanks for the replies.
The door glass holders on 64 are diecast & glass is set in setting tape & pressed in , 65s. are steel holders & glass is bolt in .
It seems some 64 doors don't have the slot for the lock cylinder. Between me and buddy we have 4 64s we are working on some have them some don't.
Thanks for your responses.
early 65 still used the press in style regulator . mine is a 12c car and has 64 style.
That makes sense GM said use them up ,what style lock clip ?
it has the 65 style lock retainer. oh and to add to your thought of use them up . the car is a power window car. limited use of these regulators
I am not referring to the regulator , i am talking about the glass channel holder , regulator for manual vs. power windows are totally different & has nothing to do with the regulator . Glass holders are the same for manual & power windows .
understand. but my glass is set in a rubber channel that the regulator roller rolls in. the glass has no holes.
Let's start over there are 2 types of glass holders for door & 1/4 glass , the 1st. type is Heavy chrome plated Die-cast holders that the edge of glass gets wrapped with rubber setting tape & pressed / pounded into the Diecast holder . The 2nd. & later design the glass has holes in it & gets a rubber strip around the lower edge & bolts into stamped steel holders . Both styles will accept both regulators - manual roll-up windows & power operated windows , as it does not matter what type of glass holders you have , meaning manual vs. power . The difference is the regulators , not the glass holders .
No cast, No holes in glass |
Never seen that style on a 64/65 only on a Post car ? I am referring to a non post model . What model are you referring to ?
did not realize there was a difference |
Everything is different inside the doors on a post vs. hardtop/convertible--except for the door latches.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
