Old 11-10-2016, 12:40 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default Race car gauges/dash setup
Seems simple enough, but curious what most like as far as dash/gauge setup?
Gauge brand/design
Size of gauges
Which gauges are must-have vs. nice-to-have
Where to mount which gauges (inside, outside on cowl, high, low ,etc)
Gauge face color
Mechanical signal vs. electronic
Anything else I may be forgetting?
I understand a lot of it is probably just personal preference, just figured I'd see what other guys like or don't like and take that into consideration.
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 11-10-2016, 01:21 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I have Autometer Pro Comp Mechanical in mine, water temp, oil pressure, vacuum, voltage, trans pressure, Tach ect. If I was starting from scratch, I would go with a Digital Display
Dave Polichena
Old 11-10-2016, 01:43 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I have Autometer Pro-Comp Ultralite and Silverlite (liquid filled). The top two are liquid filled mechanical gauges for oil pressure and water temp (the most important ones) and the lower left is the voltmeter and the lower right is the transmission temp gauge (mechanical). In the lower center is a small digital tach I use for setting idle and checking stall rpm (no time to look during a pass). The center red light indicates the line-loc is on and the upper red light I no longer use (used to be high EGT warning). The big warning light on the steering column is low oil pressure, big enough and bright enough to get my immediate attention.
I also log EGT's all eight cylinders, oil pressure, boost, fuel pressure, rpm, driveshaft speed and G's on a Racepak Sportsman data logger to look at after the pass.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 11-10-2016, 02:27 PM
ho428's Avatar
ho428 ho428 is offline
I went with Quickcar
http://www.quickcar.com/61-6031-gaug...ing-light-kit/
I added an oil temp gauge to these three, and with the warning lights they are all I've needed.
They offer a lot of different packages though.
Old 11-10-2016, 03:26 PM
racegto65's Avatar
racegto65 racegto65 is offline
Matt, what are you planing for a dash or mount?
My race car is a '65 GTO and it has a pretty simple
aluminum dash in it. Autometer guages.
I'll take some pictures this weekend and pm them to you.
Might give you some ideas.
Bill
Old 11-10-2016, 03:27 PM
LT's Avatar
LT LT is offline
Speedhut
Sent from my SAMSUNG-SM-G900AZ using Tapatalk
Old 11-10-2016, 04:33 PM
Bill
I'll be doing something similar, just a simple aluminum dash.
Matt
70 GTO 400 4-speed
Old 11-10-2016, 06:00 PM
Very cool, I like what I see there... i'd like to do something like this, warning lights would be handy. Any other companies do anything similar?
Matt
70 GTO 400 4-speed
Old 11-10-2016, 09:24 PM
YES warning lights! Years ago when I went with the big Autometer tach with shift lite I quickly found the light more useful than watching the tach. The light really improved my consistancy. I later went with a smaller tach(Sun super tach II) and a separate shift light. I like mechanical gauges(good accurate results with both Sun and Autometer) and when possible warning lights to direct your attention to the gauge.
Old 11-11-2016, 01:08 PM
I agree Bruce.
I thought I wanted a big analog(needle) tach, but wonder about digital... pros/cons?
Suggestions for digital tachs that I can check out?
Matt
70 GTO 400 4-speed
Old 11-11-2016, 05:09 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Mine is attached. Autometer Sports Comp. Tach, oil, water, volts, oil temp. On the steering column is the shift light and an innovate AFR guage (hard to see in the pic). I'll likely get a brake pressure guage in the spring.
But if I was starting over I'd get the Racepak.
Old 11-11-2016, 09:02 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
I went to upgrade my gauges, but with the racepak it was actually cheaper to buy a dash than new guages.
The sensors cost about what a good gauge will cost, and if you want it to be displayed by a guage, you're going to want to log that measurement going down the track.
The dash can also display warnings and flash warning lights like low oil pressure. It can also flash as a shift light, but I use one in connected to the MSD as its easier to change since I'm in the box in between rounds and almost never in the dash changing settings.
Old 11-13-2016, 03:15 PM
WARPed's Avatar
WARPed WARPed is offline
RacePak
http://www.racepak.com/collections/d...nt=18332654339
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 11-14-2016, 02:29 AM
racegto65's Avatar
Matt, here are some pictures of the dash in my '65.
Simple but functional.
ID:	440728   Click image for larger version
ID:	440729   Click image for larger version
Old 11-14-2016, 10:17 AM
Mr Anonymous's Avatar
I am usually a huge fan of mechanical gauges, but I went 100% electric on my latest car. I remove 4 screws, unplug a connector, and that part of the dash is out of the car. I have my main electrical junctions behind that part of the dash, and easy removability is a plus.
Clutch Guys Matter
53 Studebaker, 400 pontiac
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
Old 11-19-2016, 12:17 PM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Here is my old school gauges for my old school project.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
Old 11-19-2016, 03:24 PM
I like it.
I've decided that I too like the old school look of some gauges.
Happened upon a killer deal on a matching set of autometer gauges, all new in their boxes still so I picked em up. Got pro comp 2 silver face memory tach w/ shift light, and matching water temp, oil pressure, trans temp, fuel pressure, and nitrous pressure (which I may or may not need). I'd like to pick up a voltage gauge and a wideband air/fuel gauge as well.
That being said, I like the idea of a data recorder, so I want to eventually pick up a Racepak Sportsman Data Logger.
Only concern is the fuel pressure, water temp and oil pressure gauges are all liquid-filled... figured on mounting the gauges in the dash, except fuel gauge will probably be mounted on the cowl? But I've heard good and bad about liquid filled gauges so not sure how I feel about that yet... figure I'll give em a shot.
Matt
70 GTO 400 4-speed
Old 11-19-2016, 04:02 PM
I went with the same tach, with shift light, red oil pressure, & blue water temperature warning lights. On track I don't read gauges, but warning lights will get my attention.
Old 11-19-2016, 07:03 PM
Old Man Taylor's Avatar
I'm a little late to the party. In the dash I have water temp, fuel pressure, oil pressure, trans oil temp, voltmeter, and a gas gauge that I later changed to a vacuum gauge. Below the dash is a brake pressure gauge.
Name:	Tempest Dash Inside.jpg
Old 11-26-2016, 03:37 PM
Johannsson's Avatar
Johannsson Johannsson is offline
My 65's...
ID:	441379   Click image for larger version
1965 Pontiac GTO 389 Tri Power 4 speed
1965 Pontiac GTO 517 N/A (5.17/135mph 1.17 60f)
1965 Pontiac Tempest N/A 428 (9.81/138mph )
