New Best Today
I got my first 9 second time slip today. I was planning on running half track at my local track, and then going to MDIR on Sunday the 27th to stretch my legs. My local track cancelled the race due to weather. I decided to drag my junk to Richmond Dragway and run the 1/4 mile during their last test-n-tune of the season.
Pass #1 I had a slight stumble (first pass since 1 Oct) and run a 10.00 @ 136 with a 1.49 60'. After a minor carb adjustment, I had a good clean launch on the second & third pass. 9.87 @ 136 And 9.86 @ 136. The last pass I forgot to reinstall the fuel cell cap...it smelled really bad on the return road. Anyway, I guess I'll stay home and watch some football tomorrow, no reason to drag my junk to MDIR now. DA was right at sea level, 175'.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Good job!
Nice!
Congratulations on reaching the nines!!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
That's awsome. Congrats to everyone involved.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
REAL NICE |
Congrats on the the 9's!
That's kickin it.....congrats
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
Contacts that's moving. What was carb adjustment if you don't mind? I run e85 too and sometimes it doesn't want to come Up on the brake cleanly. Although I think it may be fuel related. I had some that was lower E than I thought
Nice passes. Congrats!
Brian
Boobs & bacon |
Opened all four idle screws another 1/4 turn, from 2 1/2 to 2 3/4.
Congrats! Some nice numbers for sure!
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 |
Congratulations!! I know exactly how you feel!!!! I am still stoked on my first 9, you will be,too. After a couple of days you will start thinking on how to get to 9.70's.
What does you car weigh? I made some changes to my car and decided to drive to the co-op and weigh it, I was surprised to find out the 69 bird is heavy 3640 lbs. WITHOUT me in it, that would make 3840 race weight. So now I am curious of the weight of your car and if you removed any weight out of it. Steve
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot. |
Man, I am over here excited for you. I was about to go watch you race at MIR today. Glad you posted this. Richmond is only 1 hour from me, if you go back call me 703-615-5027 and I can get a few other Pontiac's out there and have our own Pontiac's in the Park event.
I'm also thinking about a Pontiac dyno day at my shop if I could get some people interested. There would be no charge as it is just another tool in the shop and not my primary business. Steve
Thanks everyone!
I took about fifty lbs off my car last winter, it's now about #3350 when I'm staged and ready to race. I knew the weight loss helped lower my ET all through the year, but I didn't have a time slip to back it up. I missed the spring window to get the slip due to cancelled races and parts that needed rework. The day of my signature video I ran 6.32 three times (with my old wheels) so I knew it was faster. That's why I made a special trip to Richmond yesterday after my local track cancelled their "Last Man Standing" event. This was only the second time running 1/4 mile this year. I enjoy the thrill of the second half of the race track. This is the fastest this car will ever go most likely. It has a mild steel roll bar only, vice the required cage and associated safety gear. I have another car that will be certified to run much faster, it's a back burner kind of deal, but I'll finish it one day. This car will see street duty again with a 455, Muncie 4 speed and 410 gears, just like I drove it for decades. I'm planning on attending Richmonds race on New Year's Eve this year. That dyno deal is tempting too. Thanks for the offer Steve! CVMS & Dave Wilcox know what they are doing.
Congrats, that's hauling! Still running the 300b?
Yup. I can't justify running a roller cam when you can make enough power to split a stock block in half with a solid cam. My next engine (car) will step up to all the good stuff, until then I'll keep running the old school junk.
Good work!
How much work has been done to the heads? That thing is flat hauling the mail!
That's very fast! Great job
