Old 12-01-2016, 12:19 PM
SD73's Avatar
SD73 SD73 is offline
Originally Posted by njsteve View Post
Add another one to the 1B11 list. This is the starter from the 11,000 mile, formerly flame painted, SD455 4 speed that was at MCACN last year. So far everyone I have contacted with an unrestored 1973 SD455 with gapless provenance has yielded the same result of 1B11 date coded 1108436 starter.
Gapless provenance would mean we have a very early build and a very late built SD with that starter. Do we?
I know it sounds conclusive, but some build dates would be helpful here too. I know I am the odd man out with my 500. And I know the AMA called for the 436.
My car is one of the earlier cars built. Last time I checked it was the 6th T/A in the registry. It's a first week of June car.
I bought it from the 2nd owner who had it since '74.
Second owner gave me the receipt with the car for the starter service he had done which was having the solenoid replaced.
The starter is dated a few weeks before the build date.
So does anyone have a a car first week of June or earlier with a 436?
  #5102
Old 12-01-2016, 03:05 PM
Good questions, SD73.
Is yours a 4 speed?
I would ask that also.
Possibly the 4 speeds got a different one at 1st?
(the early starters)
I'd also be interested in the block date code.
(and EUN?)
  #5103
Old 12-01-2016, 04:00 PM
SD73's Avatar
It's just a lowly auto. The block date code looks to be K112, but it's hard to get a good look at. There may be a 3 before that sequence. EUN is 773700. I'll have to check my Build Sheet to see if there's more on there.
  #5104
Old 12-01-2016, 04:42 PM
njsteve's Avatar
njsteve njsteve is offline
FrankG's auto: 139XXX (late June ship)
Flame painted 4-speed: 141XXX vin (unknown ship date - I don't have the PHS)
My SD auto: 142XXX vin (mid July ship)
1700 mile auto:144XXX vin (late July ship)
  #5105
Old 12-01-2016, 04:51 PM
SD73's Avatar
Thanks, and good idea. My VIN is 137xxx.
  #5106
Old 12-01-2016, 04:53 PM
If you have the build sheet () it should have the starter number on it.
At least what they wanted to put on it.
(maybe not what was put on it)
  #5107
Old 12-01-2016, 04:58 PM
I think I remember your car now.
I think you posted it before?
I think the build sheet did show 436.
  #5108
Old 12-01-2016, 05:07 PM
The VIN's of Frank's and SD73's are close, probably the EUN is close also.
The others would have probably 50,000 to 100,000 difference, even though the date codes on block are the same probably.
With the varied ship dates and build dates, still wonder how they selected the engines for the cars.
  #5109
Old 12-01-2016, 05:08 PM
SD73's Avatar
Yeah, I just verified. It does show the 436. Did it really get it though? Could be, but like I say the build on the starter in there is oddly dated coming from a previous owner who was not into those sorts of things.
  #5110
Old 12-01-2016, 05:10 PM
What was your date code on the starter?
(500 starter)
  #5111
Old 12-01-2016, 06:36 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Steve, I would think the EUN would be a better indicator of engine build date and maybe to see if there was a correlation to what starter may have been installed. What are the EUN's of these other engines? It'd be interesting to see how many units seperated the June car from the late July car.
  #5112
Old 12-01-2016, 06:41 PM
Larry Navarro's Avatar
Since we are discussing numbers.......I have a set of spiral shocks that came off my old SD. The date code is of '73 vintage. I replaced them with VSE 3-way adjustables a few years before I sold the car.
Don't know if they can be rebuilt to improve damping action but would work quite well for a correct numbers restoration. I have no use for them now.
  #5113
Old 12-01-2016, 06:59 PM
SD73's Avatar
John, I believe it's May 23, '73. It should be posted upthread here somewhere too.
  #5114
Old 12-01-2016, 08:01 PM
njsteve's Avatar
This is mine from the Formula:
  #5115
Old 12-01-2016, 08:44 PM
About 95,000 between them.
The thing is the block date codes are K112 for both and most 1973 SD's.
For the SD's it would seem the engines were sitting at Norwood (or engine plant?) for quite a while before being put into cars?
(November to June at least)
So with Steve's and others, the starters were sitting somewhere to be put on these SD's for even longer?
(Feb 1971 to Nov 1972 at least)
  #5116
Old 12-02-2016, 03:18 PM
shocks are no longer available.
  #5117
Old 12-02-2016, 11:49 PM
.......found a nice SD distributor GEAR that needs a new home.
  #5118
Old 12-03-2016, 05:13 PM
74 SD455 Formula 74 SD455 Formula is offline
I did'nt see it offered in the parts for sale section. How much did you want for it as I know someone who may need it ?
  #5119
Old 12-13-2016, 04:40 PM
njsteve's Avatar
Here's another 1B11 starter on a 10,000 mile 1973 SD455 T/A.
Name:	starter 10k mile 73 auto.jpg
  #5120
Old 12-13-2016, 04:46 PM
What kind of build date?
Cool find.
