SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 01-08-2017, 04:47 PM
ken66 ken66 is offline
Default 6x-8 Heads
Date codes D236 and D276. Unported, 1.77 exhaust valves, not sure of combustion chamber size, but my understanding is that they have only been milled for flatness so they should still be around 100. These heads were redone in 2002 or so and were on a running engine for a few hours until I discovered that the thrust bearing ate my crank. Even though they have very little time on them, I consider them cores because they have a few issues (below).
The good: very clean chambers, free of pits, larger exhaust valve, guides cut for positive seals, basically new exhaust valves and 988-16 springs. Springs installed at 1.6.
The bad: (1) One of the exhaust manifold bolt holes was moved up slightly (see last photo). It will need to be recentered or the manifold bolt hole enlarged. (2) Two of the valve guides were poorly cut, such that the outer surfaces are rough. For one valve, I could not fit a viton seal over the guide and had to use one of those plain old black valve seals. (3) No studs or guide plates.
I hope someone can use these. How about $80 plus the ride from 22207? If you're local maybe we can work something out to avoid shipping.
Old 01-13-2017, 10:19 PM
Bump. Price drop to $60 plus the ride.
Old 01-14-2017, 06:08 PM
blueghoast's Avatar
Default 6-x 8 Heads
Where are you located? Don't know my zip codes LOL
GT.
Old 01-14-2017, 08:15 PM
Sorry. Arlington, VA.
Old 01-15-2017, 11:24 AM
Pm sent
Old 01-16-2017, 04:43 PM
Pm returned.
Old 01-17-2017, 09:45 AM
Back at you.
Old 01-22-2017, 01:24 PM
Sold. Thanks Brian and thanks PY.
