Old 01-22-2017, 01:12 PM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
Default New Member and his 71 LeMans Sport
What a nice forum! So much info to digest...I am new to the Pontiac Scene as I have 2 Camaros as well 1968 and a 2010..both blue.
When I found this 1971 LeMans Sport in Elwood, Indiana, I knew I had to have it.
I would like to start a "Build Thread" on her, but did not see any such forum.
Here are just a couple of photos the way we brought her home. I have since begun to disassemble her for the rebuild. I would like to post ongoing photos as I make progress.
Please let me know if I am within the boundaries of doing this!
Thanks again,
Kurt L71S
Name:	71 Lemans begin to disassemble 001.jpg
ID:	445518   Click image for larger version
ID:	445519   Click image for larger version
Name:	71 Lemans begin to disassemble 004.jpg
Old 01-22-2017, 01:21 PM
You found the right sub-forum for your build thread, start a new thread and post away!
Welcome to the PY forums
Bart
Old 01-22-2017, 02:03 PM
Kurt L71S's Avatar
Thanks so much B-man....
Kurt L71S
Old 01-22-2017, 02:58 PM
indymanjoe's Avatar
Car looks great! welcome along!
I am the Thread Killer!
Old 01-22-2017, 06:27 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Welcome to the forum! Nice looking car!
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 01-22-2017, 09:00 PM
Txbobcat Txbobcat is offline
It looks good to me.
Old 01-23-2017, 09:19 AM
Kurt L71S's Avatar
We started ripping her apart just about as soon as we got her home! I had rebuilt our 1968 Camaro Sport Coupe the same way, so I figured why not try a Pontiac LeMans...can't be that tough, right?....
Kurt L71S
Name:	71 Lemans begin to disassemble 003.jpg
ID:	445571   Click image for larger version
Name:	71 Lemans begin to disassemble 008.jpg
ID:	445572   Click image for larger version
Name:	71 Lemans begin to disassemble 014.jpg
ID:	445573   Click image for larger version
Name:	71 LeMans Front End Removal 001.jpg
ID:	445574   Click image for larger version
Name:	71 LeMans Front End Removal 013.jpg
Old 01-23-2017, 09:31 AM
Kurt L71S's Avatar
I had some wonderful help on this car just like Grandpa's 68 Camaro....Our Son-in-law Clint Minglin and our Grandson Jackson Edward!...
I need to mention that this car is an Indiana car...that being said, I crawled under it with a fine tooth comb and found only 2 little rust holes from the interior....That is unheard of! All of the original fuel, brake lines were intact with their fasteners as well...
My plans for this car is a complete frame rebuild with new tank, lines, 4 wheel disc conversion from Pirate Jack Hot Rod...with red calipers!.....
Then off to the body shop for a fresh coat of 1989 Chevrolet Blue, along with new bumpers and chrome emblems.
After that, I am going to replace the entire white interior with new from top to bottom....
This sounds like a bunch of work...and it will be!! But the end result will be so worth the effort and money.
Stay tuned for more on this project....I am open to suggestions along the way, so don't hesitate to speak up....
Regards,
Kurt L71S
Name:	71LeMans Engine Removal 007.jpg
ID:	445576   Click image for larger version
Name:	71LeMans Engine Removal 012.jpg
ID:	445577   Click image for larger version
Name:	71LeMans Engine Removal 022.jpg
ID:	445578   Click image for larger version
Name:	71LeMans Engine Removal 029.jpg
ID:	445579   Click image for larger version
Name:	71LeMans Engine Removal 034.jpg
Old 01-23-2017, 09:40 AM
Kurt L71S's Avatar
Maybe just one more today to help get caught up a little. Fast forward some...Removed the engine (350), and Trans (TH350), began cleaning the frame and doing some inspection....She's clean from end to end....So stoked on this LeMans!
I pointed out some of the weld lines on the frame....hand welded back then....some of the wire was STILL on the welds...
Removed the tank! Did not find a build sheet....Boo!!
Kurt L71S
Name:	71 LeMans Clean Frame 001.jpg
ID:	445581   Click image for larger version
Name:	71 LeMans Clean Frame 006.jpg
ID:	445582   Click image for larger version
Name:	71 LeMans Clean Frame 008.jpg
ID:	445583   Click image for larger version
Name:	71 LeMans Clean Frame 011 weld.jpg
ID:	445584   Click image for larger version
Name:	71 LeMans Clean Undercarriage 007.jpg
Old 01-23-2017, 10:07 AM
Kurt L71S's Avatar
Just messing with my sig and photo!
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
Old 01-23-2017, 11:05 AM
indymanjoe's Avatar
I see a pattern with the color's. Nice cars!
Old 01-23-2017, 01:26 PM
Kurt L71S's Avatar
Thanks Joe! That is what caught my eye...The blue and the white interior! I have always wanted a car with white interior...
I almost installed white in my 68 Camaro....but decided against it...
Old 01-23-2017, 01:52 PM
Looking at the pics you have a fine example of a restorable car there. You got lucky!
Guard that front bumper with your life, they are kind of tough to come by. The rear ones you can get easily, those fronts are few and far between. (I had one swapped when I took my original to a rechrome shop, was NOT happy)
If you're going to have it painted, you might want to consider dropping the frame and having it powder coated, it's not that bad to do.
Old 01-23-2017, 03:02 PM
Kurt L71S's Avatar
I consider myself Blessed! As far as the bumpers, the front is pretty good...I need to straighten it a little in the middle. I hope I don't crack the chrome, but the rear I am going to replace...
I already have split the frame and the body. I am now replacing all the bushings along with all brake and fuel lines and return lines. The frame is now painted and ready for me to start the reassembly...
Old 01-23-2017, 05:34 PM
Kurt L71S's Avatar
As I progressed some, I ordered ALL new Moog ball joints, bushings for upper and lower A arms, rear upper/lower Control Arms. We sure want her to ride and drive like a new one!...
Had to, at the same time purchase a few new tools to do the work. Control Arm Bushing tool, floor press, Ball Joint press and Removal tool...
Name:	71 LeMans bushing installs 004.jpg
ID:	445627   Click image for larger version
Name:	71 LeMans bushing installs 006.jpg
ID:	445628   Click image for larger version
Name:	71 LeMans bushing installs 009.jpg
ID:	445629   Click image for larger version
Name:	71 LeMans bushing installs 010.jpg
ID:	445630   Click image for larger version
Name:	71 LeMans bushing installs 003.jpg
Old 01-23-2017, 06:04 PM
Kurt L71S's Avatar
I had a visit from Clark Gick of Basic Body & Paint, Inc. in Chalmers. He looked "Blu" over and gave her the thumbs up for some new paint!....
I am beyond stoked! He told me that this car is so nice for being an Indiana car and also being a 1971! That's all I needed to hear. I started ripping the undercarriage apart! Getting ready for another 4 wheel disc brake conversion!
Even though Pontiac was part of GM, things are so different from Chevrolet! Seems like everything is on the "other" side from what the Camaro is...Oh well....One never wants to quit learning!...
Name:	71 LeMans-Chassis cleaning 011.jpg
ID:	445633   Click image for larger version
Name:	71 LeMans-Chassis cleaning 005.jpg
ID:	445634   Click image for larger version
Name:	71 LeMans-Chassis cleaning 012.jpg
ID:	445635   Click image for larger version
Name:	71 LeMans-Chassis cleaning 016.jpg
ID:	445636   Click image for larger version
Name:	71 LeMans-Chassis cleaning 017.jpg
Old 01-23-2017, 10:16 PM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
Default looks like fun!
fun thread.........don't lose hope on build sheet yet.......found a like new one for a 72 GTO taped neatly to backside of drivers inner door pad........have fun, SLASH.
70 GTO 400/[email protected]
Old 01-24-2017, 12:20 AM
Judge-1969's Avatar
Judge-1969 Judge-1969 is offline
Great looking car! Neat to see some of your work on a '71! I would like to do a few things to my Lemans in the near future so I'll be keeping tabs on yours!
How long have you had it?
Tyler
1971 Lemans Post
Old 01-24-2017, 07:42 AM
Kurt L71S's Avatar
Thanks Goat!
I appreciate your thoughts!
Old 01-24-2017, 07:44 AM
Kurt L71S's Avatar
Thanks SLASH!
I will make sure to look everywhere in the interior...Nice tip!!...
