Instead of just wrapping the crankshaft with giant hunks of plastic what have you guys used to do this?
I plan on making it so it can be moved and with these deals being so long and heavy I want to be sure that it has a good seal on it. I plan on using a couple packs of dry gel to keep the water off of the crank itself. Any tips?
![]() 69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Standard procedure is to first spray it well with a preservative like Fluid film or PB Blaster's similar product & wrap it well. A roll of saran wrap would go a long way. Maybe some heavy mil plastic.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
On nice core crankshafts, for the last 25 years, I've sprayed the mains & rod journals with Kano Products WeatherProof. When dry, it leaves a relatively thick amber colored film which prevents any rust. To remove one will need to submerse the crank in ones solvent tank, or have machine shop hot tank.
I leave mine standing in the corner bare. Knowing any of them would need to be polished/machined so to me surface rust isn't of concern.
If you think you'll be moving them/it around a bit I would suggest a homemade wooden box.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
![]() Quote:
![]() Quote:
After I pposted this I thought about making a ziptie handle out of the huge zipties I have that are two feet long and wide. I am guessing that after I wrap it that I could ziptie the ends and create a handle using them since they are plastic and will not rust or bite into the crank end journals.
If you have room under a shelf or work bench it's best to store one hanging and out of the way.
On the floor stored in corners I've had mice get in and use the counterweights as condo's, didn't realize that until I unwrapped them.
https://www.facebook.com/Outlaw-Vint...7899333725868/ |
