Old 02-14-2017, 04:17 PM
ambmech1's Avatar
ambmech1 ambmech1 is offline
Send a message via AIM to ambmech1 Send a message via Yahoo to ambmech1
Default 4 spark plugs with 0 gap
1970 ys 400. Mild cam, Headers, quadrajet with cast iron intake.
Just before putting the car away this past fall I had an issue after starting it. Ran very rough like missing a few cylinders. Pulled the plugs and found 1,7,4, and 6 with the ground electrode bent over and touching the center electrode. No mechanical damage noticed. Other 4 plugs were fine and burning normal. Light tan color. Put new plugs in and it's fine. No noise and running strong and smooth. A little research and it may be a detonation issue? Being a dual plane intake is one side of my carb malfunctioning? Anyone ever run into this? Seems to run fine now but I'm worried it could happen again with more serious consequences.
Thanks in advance,
Joe.
Old 02-14-2017, 04:23 PM
STEELCITYFIREBIRD's Avatar
Pictures of plugs?
Old 02-14-2017, 04:33 PM
ambmech1's Avatar
Here's 3. 1st pic shows one of the good plugs.
ID:	447229   Click image for larger version
ID:	447230   Click image for larger version
Old 02-14-2017, 04:36 PM
ambmech1's Avatar
Running stock HEI. Gapped at 45.
Old 02-14-2017, 04:43 PM
I can't think of anything doing that except mechanical contact.
Old 02-14-2017, 05:39 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
1746 would be one side of a dual plane. Hmmmm
The good plug gap looks kinda wide.
Ok so if something like a small nut fell in one side of the manifold, it could possibly bouce around and go between those 4 cylinder hitting those plugs before shooting out the exhaust. Sounds unlikely but possible?
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 02-14-2017, 05:40 PM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
I hope there's nothing floating around in those bores...
My knee-jerk reaction was that this would have to be a mechanical thing... but I have been wrong many times before...
1970 Formula 400
Old 02-14-2017, 06:10 PM
1968GTO421's Avatar
Keep us posted on how the new plugs are doing while we all scratch our heads over this. Reminds me of 25 years ago and timing belt breakage on a certain 4 cylinder car (not ours) that I worked on, except the valves and plugs were flattened and pistons cracked.
GTOAA--https://www.gtoaa.org/
Old 02-14-2017, 07:59 PM
My best guess is that you opened up the gap and the electrode hit the plug hole threads while screwing them in, closing the gap a good bit causing them to eventually foul. Then when you wound them out they got shut completely from the deposits.
Old 02-14-2017, 08:37 PM
Joel Koontz Joel Koontz is offline
Are there any thread marks on the back side of the electrodes that are bent shut?
Old 02-14-2017, 08:49 PM
ambmech1's Avatar
Question
Would a lean condition cause the ground electrode to get super hot and bend? I just find it weird that it coincides with the upper plenum of the intake manifold. Not Pontiac but on searching the internet there is reference of detonation overheating the tip of the plug and basically hammering it. I would think if it was detonation it would affect all cylinders.
Old 02-14-2017, 08:53 PM
ambmech1's Avatar
That's what's baffling there are no marks on the tip of the plug. Almost like it's melted and just dropped down.
Old 02-14-2017, 08:58 PM
I am not referring to the tip, but the part that is directly above the threads.
If the bend of the electrode was such that it stuck out past the threads, screwing the plug in would push the electrode in/down.
Old 02-14-2017, 09:15 PM
tom s tom s is offline
something had to hit them.Tom
Old 02-14-2017, 09:26 PM
dmac dmac is offline
Gremlins, I've had lots of them messing around in my cars.
Old 02-14-2017, 09:38 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Subscribed because I love a good mind teaser!
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
Old 02-14-2017, 09:41 PM
Did my neighbor put the plugs in?
Old 02-14-2017, 10:16 PM
1746. what are the chances. thats one side of a dual plane manifold. flying debrie will be issolated to one side of the manifold because of the divider. seems freaky, BUT 1746. that's too much of a coinidence. if you're not sure what im talking about, one side of a dual plane is 1746, the other is 2358. coincidence?
Old 02-14-2017, 10:22 PM
Correlation to the intake feed split can't be a coincidence, I agree.
Old 02-14-2017, 10:47 PM
AdamIsAdam's Avatar
carb parts falling into the engine? How's it running now?
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
