Old 01-11-2017, 07:01 PM
RocktimusPryme's Avatar
Originally Posted by 68400BIRD View Post
I looked at my receipts and I bought mine from Auto City Classic. It has the large two rows.
Here is a link.
http://www.autocityclassic.com/camar...diator-6769at/
Okay cool. That looks identical to the one I had been eyeing on eBay.
Old 01-11-2017, 10:51 PM
GregL's Avatar
GregL GregL is offline
Alright, did the install today. Whole thing took less than an hour. I'm pretty fussy about fit and original look. I was going to paint this radiator black more like the orig. but decided against it in the end. It is as close to a direct bolt in as you're likely to find. Comes with a cap and petcock installed.Original cap fits fine. Only mods I had to make: I needed to hog one mounting hole just slightly and there was no boss to accept clips for lower mount of shroud. I jiggered together an acceptable, secure replacement. Temp here in the desert today was 70 degrees. Started up and idled for about half an hour. At first I didn't think I was going to get hot enough to open the thermostat, but it did. On test drive guage showed considerably lower than before. I'm anxious to see how much cooler it will run once we get back up in the triple digits. In short, I'm very satisfied and would recommend this upgrade to anyone.
Old 02-09-2017, 01:18 PM
Speargun's Avatar
Speargun Speargun is offline
I installed the Champion 4 row in my '67 bird & had to "massage" a hole or two, but nothing major. My original plan to use a Mark VIII fan wouldn't clear the water pump so I threw an old Black Magic 15" electric fan/shroud on it. This setup leaves about 3-4 inches on each side unshrouded.
Running down the road it stays around 185* - 190*, but once I get in town & hit 3 or 4 stop lights, it will start creeping up to 210* - 220*. I think this more of a shroud issue so I have an aluminum shroud & 2 12" fans on the way for it.
They say the 4 row will cool up to 600hp & I'm pretty close that so I'll see how well it works this summer in the Florida heat.
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 02-25-2017, 12:26 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
The two core that I ordered has more cooling capacity than the four row. I did a lot of research and found people had better luck with the two core.
The two row you have is completely different configuration than the 2 row that Champion offers. The Auto City Glass unit has 2 1" rows. The Champion has 2 5/8" rows. 2 1" rows cools about 10% better than the champion 4 row. Our Cold Case unit has 2 1 1/4" rows which will cool even better. That doesn't mean everyone needs the biggest radiator. However, it at least gives you a guide to the range of cooling capacities available on the market.
To a lot of people researching aluminum radiator options, it's very confusing at first.
Just wanted to bring this to attention for those that stumble upon this topic.
Old 02-25-2017, 12:33 PM
Ccass's Avatar
Administrator
If after you have run it in the summer out there and find you are even just a little bit uncomfortable with the temp, I'd like you to consider trying our Cold Case unit for comparison. I'd send it out a no charge to you if you report back the results.
